Old 12-23-2008, 09:47 AM   #1 (permalink)
Grille Block
Well, it's about -26 C here so I used black duct tape across my Saab's grille as a winter front. I guess I've got my first aerodynamic grille block too. :-)
Looks fine and only took 5 minutes.
Old 12-23-2008, 12:51 PM   #2 (permalink)
winter
The cold temps are going to make it very problematic to see any mpg benefit from the grille-block.You may have to wait 'til spring before results emerge from the background noise of winter driving.
Old 12-23-2008, 01:01 PM   #3 (permalink)
Hi,
I have been running almost a full year with tape as a grill block -- I use Gorilla tape, though I started with transparent duct tape, and I tried Weatherseal tape, as well.
Old 12-24-2008, 12:29 AM   #4 (permalink)
Yeah, any significant mpg gains will come from running a warmer engine.
Hey, I could have used the silver duct tape spaced 1/4 inch apart and it might have looked like a Taurus grill. :-)
Old 12-24-2008, 01:58 AM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Gorilla - Camo tape :P
That would have been pimp.
Old 12-24-2008, 09:46 AM   #6 (permalink)
Hi,
Aerodynamics are even more important in the winter: I noticed that with frozen slush stuck to my car, my mileage stayed below 39mpg, and after cleaning it off, I got the average up to 41mpg again.
How does a grille block improve warmup time? fanamingo EcoModding Central 30 05-03-2010 05:13 PM
Help me decide the shape of my grille block openings! Tango Charlie EcoModding Central 1 11-16-2008 04:00 AM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 10:24 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
