Old 04-08-2013, 09:57 AM   #1 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Eco Headlights measured and compared
I bought a pair each of Sylvania EcoBright bulbs and Philips EcoVision, both 9003/HB2 size.
OEM bulbs: 51 (spec 55W)
Philips: 44W
Sylvania: 44W *
*Sylvania's bulbs start out at 48W and slowly drop to 44 after about a minute. The Philips bulbs start and stay at 44. It's possible the Sylvania's would drop even lower with more time but I stopped to not drain my battery.
Combined results (with LED tail & marker lights), car on but not running.
StateOEM power drawEco power draw
No lights38W38W
Running/marker + taillights66W41W
Headlights168W129W
That's a 23% improvement.
I am currently running the Sylvania Ecobrights because of the dropping power consumption. They might (probably will?) settle at lower power than the Philips after a minute of warmup.
Brightness and color are the same with all 3 (oem, philips, sylvania) under the scientific test of "stand 50 feet away and look at them".
The Following 6 Users Say Thank You to PaleMelanesian For This Useful Post:
AndrzejM (04-08-2013), California98Civic (04-08-2013), Jyden (04-08-2013), paulgato (10-08-2013), Piwoslaw (04-08-2013), Xist (04-08-2013)
Old 04-08-2013, 11:01 AM   #2 (permalink)
Hypermiler
Wagons
headlights: 14W saved, $13 spent
LED's all around: 25W saved, $110 spent
The Following User Says Thank You to PaleMelanesian For This Useful Post:
Cobb (04-08-2013)
Old 04-08-2013, 12:53 PM   #3 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Thanks for sharing
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 04-08-2013, 12:54 PM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
No lights38W38W
Headlights168W129W
That's a nice improvement. How did you measure the baseline power draw of 38watts?
Old 04-08-2013, 01:22 PM   #5 (permalink)
Hypermiler
Wagons
All of this is measured by disconnecting the positive battery cable and inserting an ammeter, then multiply by 12 to get Watts.
Car draws 0.18A = 2W just sitting there, from remote door locks to security to radio memory and other stuff.
Old 04-08-2013, 01:53 PM   #6 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
not a 100% accurate way of measuring wattage, but close enough if the battery voltage didn't drop too much between the first and last test.
Old 04-08-2013, 02:04 PM   #7 (permalink)
Hypermiler
Wagons
I did a test with OEM again at the end for just that reason. Results were within a couple hundredths.
Old 04-08-2013, 03:45 PM   #8 (permalink)
If you have 7" diameter round headlights then you can use these:
Truck Lite 27270C LED Headlamp 7" Round
They are just 1.8A at 12.8v for low beams. They also make 5" x 7" rectangular LED headlights: Truck-Lite 27450C LED HeadLamp 5" x7"
Old 04-08-2013, 04:12 PM   #9 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Thanks for testing the headlights. I've seen them available but wasn't sure how much power theywould save.
Coast long and prosper.
Old 04-08-2013, 04:15 PM   #10 (permalink)
..... i don't know if you would ever make that investment back?
