Old 01-22-2013, 05:30 PM   #1 (permalink)
o - '84 Ford F150
voltage gauge issue
so today i was finishing up my aftermarket gauge install on my truck and the two ring terminals on the back of my volt meter weren't a 100% tight and while the truck was running they made contact and now the gauge wont register at all. now is there a fuse inside the gauge or did i just destroy a brand new gauge because?
Old 01-22-2013, 08:18 PM   #2 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Is it possible the source used is fuse. Use a multimeter to check if there is still have 12V coming to the meter and the ground is still good. A 12V light bulb can be used to test if you don't have a test meter, just place it across the two leads. The odds that the gauge has an easily replaceable fuse are slim, if it's digital it may have a solder in component used as a fuse on a circuit board. It can be tiny, usual the first device on the positive, sometimes negative side. Good Luck.
Old 01-23-2013, 10:49 AM   #3 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
The volt meter should be fine. I think you blew a fuse in the fuse panel.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 01-23-2013, 12:27 PM   #4 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
agreed with above wherever your guage was installed to probably blew the fuse the line was on. Very rarely does a car blow up devices as long as there is a fuse on the line which unless you took a power wire from the battery to the gauge the car should have the fail-safe fuse
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 01-23-2013, 09:14 PM   #5 (permalink)
o - '84 Ford F150
thanks for the fast replies the fuse being blown was the issue i swapped in a new fuse and it works again.
