Old 02-02-2009, 12:42 PM   #1 (permalink)
TacoModder
mobilerik's Avatar
rik's prerunner - '03 Toyota Tacoma Prerunner Double Cab TRD 4A
90 day: 29.68 mpg (US)
Front Wheel Skirts are a Go!
Since everyone loves front wheel skirts, I felt I should
invite everyone to my '03 Tacoma Prerunner thread to check out the latest install.
Questions and Comments are appreciated. I tried to provide a few hi-res pix from different angles, so you can see what I did more easily, but there are a few things you can't tell from the pix. Except for the coroplast, the entire assembly is screwed together from steel straps from Lowe's.
---> My '03 Tacoma Prerunner thread
Old 02-02-2009, 01:36 PM   #2 (permalink)
TacoModder
mobilerik's Avatar
Ok, I think the links should work now. Sorry about that. They worked on my computer!
Old 02-02-2009, 01:55 PM   #3 (permalink)
Except for the coroplast and the sacrificial cutting board pieces, you mean?
Pretty cool! It'll be interesting to see if/how it helps.
-soD
Old 02-02-2009, 02:26 PM   #4 (permalink)
TacoModder
mobilerik's Avatar
-soD
Thanks!
But no, actually, the "push plates" are pieces of clear acrylic left over from a previous project, also from Lowe's. They look like that, because I sprayed them with teflon wax.
Old 02-06-2009, 06:55 PM   #5 (permalink)
Tracy - '00 vauxhall corsa
your car looks awsome. much better than the stock pickup
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Designing/building front wheel skirts v.1.0 (Geo Metro) MetroMPG Aerodynamics 124 12-26-2012 06:15 PM
Video: tuft testing front wheel skirts (Geo Metro) MetroMPG Aerodynamics 54 10-02-2012 09:42 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
