Old 09-30-2012, 06:52 PM   #1 (permalink)
Front Wheel Strake Question (spats)
Question...
Do front wheel strakes (spats) add to the frontal area since they are directly in front of the tire ?
Old 09-30-2012, 08:17 PM   #2 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
As long as the spats are in front of wheels and not sticking out in the airflow they would not increase the frontal area. They do reshape it, I would try to have them as close as possible too the wheel to try to eliminate the low pressure zone the spat would create behind it,caused by high speed air rushing over the top of the spat.
Save gas
Old 10-02-2012, 03:56 PM   #3 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
I thought I might give you my idea on this.
If your going to build them close to the tire I would make it out of long broom bristles. This has several advantages. They aren't solid so if they hit something they won't break. If they rub on the tire they will wear instead of the tire. If a cop pulls you over for them they can be trimmed on the spot to comply with what ever they say is the law.
Old 10-02-2012, 07:54 PM   #4 (permalink)
Wheel strakes that do not stick out beyond the tires, do not increase the frontal area (which is the outline of what you see in the front).
Old 10-02-2012, 09:07 PM   #5 (permalink)
Ok, thanks.
So...
Does it matter if the front is angled in, out or straight?
At the rear wheel, most seem to be angled to push the air to the outside.
Old 10-03-2012, 03:04 AM   #6 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
This is what I put on my Civic.
Made of conveyor belt and can handle occasionally being dragged on pavement.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
j12piprius (01-04-2016)
Old 10-03-2012, 03:18 PM   #7 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Wow!
if there weren´t the bolt heads visible, I would say it's OEM...
Old 10-03-2012, 08:44 PM   #8 (permalink)
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.88 mpg (US)
Starship Resurrected - '08 Toyota Prius
Put a black sharpie on those rivet heads! Makes 'em disappear...and you'll pass the "can't see it from the grand stands" test every time. Though you'll occasionally have to reapply.
Old 10-03-2012, 11:49 PM   #9 (permalink)
CRX HF - '91 Honda CRX HF
90 day: 68.45 mpg (US)
Do people really get pulled over for having wheel strakes too low...?
