Old 05-07-2012, 03:02 PM   #1 (permalink)
Red Chicken - '95 Honda Civic LX
90 day: 42.61 mpg (US)
Shifting habits? mini P&G?
I got my MPGuino installed a couple days ago and using it has made me wonder about shifting. I can't help but notice the instant mpg shooting up while shifting. Has anyone tried spending more time between gears coasting as a sort of mini P&G?
Old 05-07-2012, 03:34 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It's only happening because you lift the throttle and the engine rpm drops ... as does the load on the engine (as it's going to idle).
At speed, you're obviously using less fuel when coasting than while accelerating.
If you want to continue accelerating, don't interrupt the process, as you'll lose speed again, and need to re-accelerate to make up for it.
Old 05-07-2012, 03:34 PM   #3 (permalink)
kgwedi's Avatar
Atos - '05 Hyundai Atos Prime AT
90 day: 21.33 mpg (US)
What you say does happen. If I am at high RPM and push in the clutch and take my foot off the gas, the overrun kicks in, and I have infinite MPG until the rpm gets down to idle speed. Then I am at normal engine on coasting.
I have found that engine on coasting MPG is very dependent on your speed. This is because you are using idle fuel. More speed means more miles while burning that fuel.
Old 05-07-2012, 09:16 PM   #4 (permalink)
Coasting in neutral my Altima got 60 MPG for every 16 MPH. 48 MPH was 180 MPG.
The Insight got 150 MPG at 16 MPH. 48 MPH was 450 MPG.
You can also calculate your coasting fuel consumption.
The Altima was just under .25 GPH 16/60 GPH
The Insight was right at .11 GPH 16/150 GPH
Coasting fuel consumption may be the same as idle consumption depending on the vehicle
regards
Mech
Old 10-04-2012, 11:11 AM   #5 (permalink)
Ranger - '94 Ford Ranger XLT 4WD
90 day: 19.99 mpg (US)
I saw the same thing when I hooked up mine. Every time you push in the clutch you get great mileage, I first thought "why not spend more time there?". But like Euromodder stated, you'll use all your fuel savings taking longer to accelerate to speed. Coasting downhill with my clutch in gets me around 120 - 150 mpg @ 55 - 65 mph. Downshifting is giving me an infinite reading. Does anyone know if the Ford Ranger cuts fuel when decelerating in gear or if this reading could be bogus?
Old 10-04-2012, 11:20 AM   #6 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Yes, you'll have to re-accelerate through what you just did, but P&G is constantly reaccelerating. Don't worry about it.
When traffic and road conditions allow, I'll stretch those changes. I was going to be out of gear anyway so I might as well make it a glide.
Transmission type Efficiency
Old 10-04-2012, 12:20 PM   #7 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
I do it when there is traffic in the way:
http://ecomodder.com/forum/showthrea...ift-17489.html
Old 10-04-2012, 06:15 PM   #8 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
I just concentrate on shifting smoothly until it gets to cruising speed. That way I can rev-match it and not have to blip the throttle before putting it back into gear.
Old 10-04-2012, 06:37 PM   #9 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
I try to rev match my cobalt, I tend to skip gears because the blasted thing cant be throttled to any paticular RPM (one of the big disadvantages of drive by wire) This means that I have to wait a relatively long time waiting for the RPMs to slowly hang and drop. I also would love to have an autotragic idle on the MT since to me its just a waste having it idle at 1k when the auto is usually around 600rpms.
I have often thought of buying an HP tuner for the 010 cobalt XFE just to force DFCO to happen instantly when gas pedal TPS=0 and RPMS are above some point. This would speed my shifting, reduce clutch wear (when I am forced to be in a hurry) and it would allow a mini P&G as I shift from 1->3->5.
Anyone have such a device there are a couple things I would love to tweek on the cobalt but I can't justify $500+ to attempt it.
Cheers
Ryan
Old 10-04-2012, 11:13 PM   #10 (permalink)
Cheers
Ryan
Hmmm Megasquirt 2 standalones are less than 500 but they don't have sequential injection...I think they might be able to control the throttle though. Obviously would be a lot of work to adapt.
