Old 06-08-2013, 10:07 PM   #1 (permalink)
Coasting in the Carolinas
wolydotmatrix's Avatar
Blue - '94 Honda Civic DX
90 day: 47.49 mpg (US)
Fuel cut
New Here,
Not sure if i am in the right section.
So I decided to bite the bullet and install a fuel cut today. I use a brake light switch mounted bellow the right horn button on my civic. Fabricated a holder and mounted to the cruise control mounting location. I used 2 wires from the clock-spring which allows for wheel mounted switch. Grabbed the two wires at the bottom of steering column and extended over to the main relay. Then I cut the 2 ground wires on the main relay and attached. Works like a charm with no CEL. Tried on the way home from work and was pleased with the modification. Looking forward to the next tank of gas. Might just refill and start fresh Monday.
LMK.
Proper Prior Planning Prevents Piss Poor Performance.
The Following User Says Thank You to wolydotmatrix For This Useful Post:
ChazInMT (06-08-2013)
Old 06-08-2013, 10:59 PM   #2 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Wow, you're a Nut! This sounds great. So am I understanding that if you go to beep your horn on the right side of the steering wheel, it doesn't beep the horn and your engine quits? Or did you mount a whole separate switch and your horn beeps with either switch without stopping the engine?
Perfect place for the post btw. & welcome to ecomodder.
The Following User Says Thank You to ChazInMT For This Useful Post:
wolydotmatrix (06-15-2013)
Old 06-09-2013, 12:28 AM   #3 (permalink)
The horn switch is always open (switch to ground), so it and the cruise switches were out. Had an extra brake light switch which served the always closed circut I was looking for. Yes, seperate switch used and both horn buttons are operational. The idea was to locate the fuel cut on the steering wheel and utilize the factory harness as much as posible.
Old 06-09-2013, 01:51 PM   #4 (permalink)
Took some pics along the way
Finished:
Old 06-09-2013, 02:54 PM   #5 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Nice setup!
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
The Following User Says Thank You to AndrzejM For This Useful Post:
Old 06-09-2013, 03:04 PM   #6 (permalink)
Thank you sir.
