Old 01-16-2013, 09:54 AM   #1 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Fuel injector signal for mpguino
I searched a while for this but could not find anything. I was wondering if the fuel injector pulse value was specific to the size of injector/ numbers of injectors or was specific to a signal from the ECU / number of injectors. I am guessing the first. Thanks.
Old 01-17-2013, 05:52 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
I don't get it. Signals from ECU are feeding injectors, so what's the difference here? MPGuino is counting time of injector to be opened, then it's multiplied by number of injectora and you can estimate an amount of fuel used.
So what exactly you want to know?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 01-17-2013, 06:28 AM   #3 (permalink)
I believe it is also looking at how long the injector is open too.
Basically if I was to switch to another ECU would this value change? I am assuming that it would not as I feel it is specific to the injector size and number of injectors which has not change. Does that make sense?
Old 01-17-2013, 06:48 AM   #4 (permalink)
AndrzejM's Avatar
[QUOTE=AndrzejM;351601MPGuino is counting time of injector to be opened[/QUOTE] That's what I said, it the same as you've said of "how long injector was opened"
If you want to move MPGuino from one car to another you have to calibrate it, and if you are chanhing ECU in the same car you should calibrate it too.
