08-12-2015, 06:36 AM
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
request - thread title correction
Hi, I don´t know where to post the request so I am posting it here. I need to change a title of already published thread (this: http://ecomodder.com/forum/showthrea...tos-32541.html)
I know I am not allowed to. Should I PM moderators or what is correct order of operations?
Thanks in advance,
Rob
08-12-2015, 08:53 AM
PM or posting the request is fine. What would you like the new title to be?
08-12-2015, 09:02 AM
I bet XL-1 instead of EV-1...
I wanted to change the title of my parallel pack tread too (as it is now a build thread, not much 'design' involved anyway, research would have been more to the point) but saw that though the first post takes the new title, the thread does not.
Would it be a good idea to make it work that way?
08-12-2015, 09:04 AM
Faster to just change it for you right now: what would you like?
I completely missed "EV1"
08-12-2015, 09:15 AM
Thanks!
I'd like the 'design and ' out of my thread title; so '2nd gen Insight parallel portable plugin hybrid battery pack build thread'
I was wondering at the time how long a thread title could be. I had it maxed out, IIRC.
It was quite artless, I confess. I mean, why would a thread title need to inform us it is about a thread?
08-12-2015, 09:41 AM
Done!
I added "Honda" too (since you now have room!) which may help with people doing Google searches in the future.
08-12-2015, 09:49 AM
Perfect, thanks!
FYI - when I hit the Thanks button it showed the thanking users frame under your post, as expected, but in between it also showed this text:
Deprecated: Assigning the return value of new by reference is deprecated in /home/ecomodder/public_html/forum/includes/class_core.php on line 2552
After a refresh it was gone.
08-12-2015, 01:54 PM
Permanent Lurker
That was FAST! Thank you very much!
