Old 12-09-2015, 01:27 PM   #31 (permalink)
Originally Posted by GearheadTool View Post
My engine did not have a thermostat in it
I wonder why?
regards
mech
Old 12-09-2015, 03:57 PM   #32 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
I thought in the last few videos you were adding coolant?
Old 12-09-2015, 04:15 PM   #33 (permalink)
No sir. I wad half attempting to top off after bleeding off air, and stupidly losing coolant from forgetting to put cap on etc etc, and half attempting to make my mixture 50/50.
I have never once seen milkshake oil, I literally check the cap after every shutdown. I also don't see any abnormal coolant bubbling, I added CLR if you see "tiny bubbles" because I took my Stat housing off today and... YAAAAAH! HORROR so. Gonna give it one more super amaze-balls flush before inserting a stat.. the was no stat and it was free-flowing the whole time.
I also see the re-emergence of a fuel power delivery problem (power to the fuel pump.) Here is that video.
Now don't get me wrong, I'm not TRYING G to blow a head gasket, but I may be inclined to put sealer in, to "help" the situation.. I torqued it down as Damm good as I could given everything that went wrong and my lack of money for more appropriate or time-intensive repairs..
I can get the car to stall by wiggling fuel pump wires.
Old 12-10-2015, 08:41 AM   #34 (permalink)
Gotcha!
The fuel pump wiring looks like 20 year old wiring to me. Typical of 20 year old vehicles.
Have you tried cleaning the IAC valve on the throttle body ?
Old 12-10-2015, 09:04 AM   #35 (permalink)
Gotcha!
If I can find someone competent, I will check it out.
Exhibit A
https://youtu.be/zDQHuBl26mg
Old 12-10-2015, 01:31 PM   #36 (permalink)
Been driving for the past hour. Stopped about 4 times ...
What it does:
1. Runs perfect
2. Tenperature gauge slowly but surely creeps up..
3. I pull over, leave car to "IGN" (Ignition/run position ??) To let fan come on and cool it down . (I also sometimes hear the fan when the car shuts off.)
4. Within 5 minutes, temperature is back normal. These past two times, it has bee within the past 2 minutes, and fan even shut off early.
What could be going on?
Old 12-11-2015, 01:21 AM   #37 (permalink)
My radiator
Old 12-25-2015, 08:07 AM   #38 (permalink)
Well, I think 2016 is going to be GREAT!
And, I say this, because, before doing anything else on the Honda engine, I quietly webt out, after waking up, and decided to do a... Compression test.
And, I came to the conclusion, that. THIS time. The reason the engine will not start.. IS:
... It did not "jump time"
... It doesn't have No Spark
It doesn't have a clogged Fuel Filter..
It is not out of gas, I am filling that tank today anyways, via a gas can..
And it may no longer have an air restriction..
And it's not "a wire that gives power to the Fuel Pump" ...
It is this: STUPID LOW COMPRESSION. 100-100-100-0 (1-2-3-4.)
Therefore, today, I take anything of value out of it, and make plans, somehow someway, to get a D16Z6 up in there.
A Y8 (or Y7? idk) or any kind of custom build, or 94-95 Teggy LS engine.. Those sound wonderful, but with the helper monkeys I will likely use to do this at THEIR HOUSE NOT MINE, EVEN IF I HAVE TO PAY FOR A TOW, I think a stock Z6 bolt-up would be great. I may even consider paying more for an engine from Lacey Auto Parts, that I can HEAR RUN, this time. Been down that road before.
No more paper towel things, EVER. It even ran decent just before it got sucked in. Lasted a little more than a day, of a sweet riding engine, relatively..
Better flow radiator, AC on right, all for the D16 going in. Z6.
Oh.. I also work for Advance Auto Parts now.
:good:
Old 12-25-2015, 07:01 PM   #39 (permalink)
Plugging the vacuum leak with paper towels was probably not the best idea. I have used screws, bolts or even line plugs to plug them in the past. Are you sure there isn't paper towel holding one of the valves open?
Old 12-25-2015, 08:08 PM   #40 (permalink)
I'm not sure, but I made serious attempt to dislodge it today. And I think I may have done it.
It is unscientific as hell, but I think I feel power slowly returning to the engine. Since we were all skeptical about this engines chances, anyways.
The latest :
https://youtu.be/7fOzuaiRyPc
