Old 01-03-2013, 05:54 PM   #21 (permalink)
givemeslack's Avatar
You read your manuals, and I'll read mine. Thank you.
Old 01-03-2013, 06:05 PM   #22 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
you have to remember that in 1992, oil was not where it is today.
Are you using the same grade, type and quality of oil you used in 1992?
no.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 01-03-2013, 06:20 PM   #23 (permalink)
Even with the best synthetic oil, I wouldn't go more than a year without changing it, as oil will oxidize, even if you're not putting on lots of miles.
I'd be surprised if any car's manual recommends you go more than a year without an oil change.
Old 01-03-2013, 07:38 PM   #24 (permalink)
Pretty sure nobody here has an Owner's Manual that specifies 3000 mile change intervals for normal usage. That makes your Owner's Manuals quite odd, don't you think?
Old 01-03-2013, 08:01 PM   #25 (permalink)
Not at all.
Old 01-03-2013, 08:06 PM   #26 (permalink)
Me thinks you aren't being completely honest:
http://www.motorcraftservice.com/pub.../96expmg1e.pdf
Old 01-03-2013, 08:19 PM   #27 (permalink)
I don't care what you think. Change your oil as often as you want, or don't change it. Push it to the maximum to save a little money.
Treat your motors any way you want.
I like my results just fine.
Old 01-03-2013, 08:22 PM   #28 (permalink)
I wouldn't consider changing the oil according to the owner's manual recommendation to be excessive. In most cars and trucks that is at 3,000 miles.
Believe it or not, fuel injectors do get clogged. The least you can do is use a high quality gasoline that has detergent added.
Also, the reason for fuel additives is mainly to overcome the detrimental effects of ethanol which is added to gasoline, (10% where I live).
I won't go into greater detail right now, but you can do the research yourself.
As noted, I have done the research. You haven't.
Old 01-03-2013, 08:28 PM   #29 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
2005 Scion xA says every 5000 miles. Just got it changed today
Old 01-03-2013, 08:32 PM   #30 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
Cool thread, I like how it's not going anywhere.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
