Old 06-09-2015, 05:45 AM   #1 (permalink)
Eddie25's Avatar
Fiesta - '06 Ford Fiesta 1.4 Ambiante
90 day: 45.9 mpg (US)
Dakar - '03 BMW f650 GS Dakar (retired)
Tucson - '07 Hyundai Tucson 2.0 GLS
90 day: 32.67 mpg (US)
fuel trim what?
i plugged in my obd2 plug. as expected my one oxygen sensor (left bank) is not functioning correctly. its not so bad as to activate check engine light but it does not cycle properly like the other one.
however on the obd2 app it shows my car having 2 fuel trims. the one cycles correctly but the other one just flatlines at like 80 or something and does not move or spike or anything. im a bit clueless when it comes to this stuff. is the fuel trim a sensor that can be replaced? the car does have poor economy recently. or will replacing the o2 sensor fix it? why 2 fuel trims?
Old 06-09-2015, 11:10 AM   #2 (permalink)
Fuel trim is a measure of how much the amount of fuel is being messed with, compared to the basic amount that is supposed to get injected. You have two of them most likely because you have two banks of cylinders. The one is stuck at 80 almost certainly because the O2 sensor on that bank is dead. Fix it, and the trim reading should start behaving much better.
Note that there are short-term trims and long-term trims as well. The long-term one doesn't tend to change much, while the short-term one changes much more. I would suggest that your second trim is the long-term one, but a value of 80 doesn't sound like a LFT value.
-soD
Old 06-09-2015, 11:18 AM   #3 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
On most obd2 cars, there are two measurements of fuel trim: short-term and long-term. Short term fuel trims(SFT) are the immediate readings that the ECU sees from the O2 sensor. These readings will fluctuate rapidly in a cycle pattern, usually around 0 if the O2 is working well.
Long term fuel trims I'm unsure about, but I think they are what the ECU sees as the direction that it is "bent" towards. Having a high positive number denotes that your car is running lean and will try to richen the mixture as you drive. Negative numbers is the opposite.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
Old 06-09-2015, 12:56 PM   #4 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
What vehicle is this on? I would expect the fiesta would have 1 pre-cat o2 sensor and 1 post-cat o2 sensor. Perhaps the app you're using mislabeled the o2 sensor? On a vehicle with a V engine and a pre-cat o2 sensor on each bank, I would expect to see 4 fuel trims: bank 1 short term, bank 2 short term, bank 1 long term, bank 2 long term
Old 06-10-2015, 12:23 AM   #5 (permalink)
09 Toyo Yaris HB (Huevos)
I'm fairly certain "some_other_dave" has the right idea on tracking this down. Start with the known issue first, the failing O2 sensor before moving on the fuel trim concerns.
