Old 10-06-2008, 12:01 PM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
What Tranny lube for '97 Civic 5-speed?
What Tranny lube for a '97 Civic 5-speed?
I asked on the Honda-Tech forum, they said "Honda Fluid". Probably a good suggestion.
I searched here and found very positive notes re. GM SynchroMesh fluid. BUt then it was recommended here for the GM Metro-Suzuki clones here and I saw no notes re. other cars.
Suggestions? Comments?
By the way, the car is doing great. Got 53.5 mpg on a 135-mile trip to NY yesterday!
Coast long and prosper.
Old 10-06-2008, 12:04 PM   #2 (permalink)
I'd find out what weight you can use in the tranny first. Then, I'd go find a nice synthetic from Amoil, Royal Purple, or Redline and use it.
Old 10-06-2008, 05:48 PM   #3 (permalink)
Older Honda transmissions (up through the early 90s at least) don't like the synthetics so much. The owner's manual for my CRX calls for 10W40 motor oil in the transmission, believe it or not. I haven't checked the later ones, but I wouldn't be too surprised to find them spec'ed for the same thing.
Check on some of the Honda forums for posts by "Mister Bone" (or "Mista Bone"??); he's a D-series transmission guru, and IIRC he does not recommend synthetic lubricants for the Honda manual transmissions.
-soD
Old 10-06-2008, 08:32 PM   #4 (permalink)
Red
Red's Avatar
Redline MTL or GM Friction Modified Syncromesh if you can find it.
Old 10-06-2008, 09:07 PM   #5 (permalink)
CAUTION: May Stink!!!
BlackDeuceCoupe's Avatar
BDC's Honda CiViC HX/Si - '98 Honda CiViC HX/Si (HX Shell/Si Swap)
90 day: 40.56 mpg (US)
Send a message via ICQ to BlackDeuceCoupe Send a message via AIM to BlackDeuceCoupe Send a message via MSN to BlackDeuceCoupe Send a message via Yahoo to BlackDeuceCoupe
I've been running Red Line MTL and/or Red Line MT-90 for 8 years ('98-'00 CiViCs).
I prefer MT-90! Some ppl mix the two - same chemistry - but its' s a waste of time, IMHO!
MT-90 takes a little longer to 'warm up' - that's all. MTL is kinda watery, but some ppl prefer that.
I have NEVER had a tranny failure, and I drive my cars pretty hard!
My trannys shift slick as snot, and you can see my FE below.
Um...
I recommend Red Line MT-90.
BTW, you might find this top post interesting...
GM Synchromesh in ITR tranny review - Team Integra
(H)ere is the most precise , coherent opinionated explanation from someone with the "correct" experience...
I have NO connection with that site...
.:: B16A2 HX/Si Coupe | '98 HX shell with full '99 CiViC Si swap | 40+ MPG
Listen to the people who fail. They know what they're talking about!
Old 10-06-2008, 10:06 PM   #6 (permalink)
the firefly - '91 Pontiac Firefly Base
Last 3: 50.5 mpg (US)
White Lighting - '94 Honda Civic HB VX
90 day: 48.65 mpg (US)
SilverBullet - '99 Honda Civic EX
I ran Quaker State GM Synchromesh in my Honda Civic tranny and noticed an improvement in shift quality and smoothness, I also ran it in my Escort GT and noticed a huge improvement IMO
The link in BlackDeuceCoupe's reply is VERY good reading.
I am going to change my VX fluid very soon and am not sure whether I will put Honda Fluid in or if I will run Synchromesh. I am most likely going to go with Synchromesh as I really doubt that I will hurt my transmission.
Honda transaxles according to many transmission mechanics are the most durable, which I think is partially due to the fact Honda has many years experience in designing High Performance Motorcycle transmissions which many people shift with out the clutch after first gear
Old 10-06-2008, 10:10 PM   #7 (permalink)
I should add that I do not believe the Quaker State version of the Synchromesh fluid was the friction modified version, which I believe is only available from the dealer
Old 10-06-2008, 10:52 PM   #8 (permalink)
Heh!
I've been involved with dozens of these gear oil threads over the years...
I've already given my recommendation, e.g. what I run in my Honda transaxles.
Whatever you guys decide to run, MAKE SURE IT'S GL-4 RATED GEAR OIL!!!
Specifically, DO NOT USE GL-5 OIL (the easiest one to find). It'll eat your synchros...
If it isn't GL-4, you're rolling the dice!
Old 10-06-2008, 11:58 PM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Amsoil MTF is labeled as being safe for Hondas, but it looks thin to me, I've also used it for 10,000's of miles without a problem in my vx, 10W40 is what is recommended in the manual and that you change it every other year (like that happens more then once in the cars life) I think next time I change tranny fluid I'll go with a quality synthetic motor oil, maybe 0W30.
Old 10-07-2008, 12:07 AM   #10 (permalink)
Originally Posted by Ryland View Post
Amsoil MTF is labeled as being safe for Hondas, but it looks thin to me...
MTG might be a better fit...
AMSOIL - Synthetic Manual Transmission and Transaxle Gear Lube 75W-90 (MTG)
Optimum piston speed? Frank Lee EcoModding Central 75 02-22-2016 04:50 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Honda civic fan speed control possible mod Vince-HX EcoModding Central 0 08-17-2008 10:48 PM
Slow Speed Issues and an Auto Tranny Bobsterz Hypermiling / EcoDriver's Ed 4 06-28-2008 10:10 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
