Old 07-07-2012, 01:58 AM   #1 (permalink)
full-size template
How DID you scale up the streamlining template to make your aero cap, boat tail, etc?
Old 07-07-2012, 09:01 AM   #2 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Post 1 of http://ecomodder.com/forum/showthrea...tml#post263738 has an updated procedure that I used( including math and measurements on how I did it. Actual measurements should be scalable to whatever your height is.
Basically, measure the height of the vehicle, figure out the 10% locations, start building the tail to get close to the height/angle at that percentage, adjust final fit once the structure is in place. I have a dial angle finder that I use to check against the floor of the shop.
Hope this helps.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
The Following User Says Thank You to JethroBodine For This Useful Post:
BamZipPow (07-07-2012)
Old 07-07-2012, 01:14 PM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Trigonometry. Nothing more advanced than what I had in highschool.
Old 07-07-2012, 03:03 PM   #4 (permalink)
how did
The original 'Template' was drawn on 11" X 17" paper with the 'ground plane' and a horizontal datum projecting rearward from the 'Max. Camber' point.
By knowing the actual ballasted height of a vehicle,reasonably accurate dimensions can be measured (in scale) at any point on the drawing,producing the necessary vectors for bulkheads,formers and stringers which define the new form.
Photo-enlargements can be stitched together with invisible tape to add 'resolution.'
A full-scale 'french-curve' of 1" Schedule-40 PVC pipe can be laid over the bulkhead stations to provide vectors for any longitudinal point along the 'Template.'
Long ago,cars were developed from full-scale blueprints.You'll see this in Martin Scorsese's movie 'Tucker The man and His Machine,' and the depiction of Alex Tremulis' blueprints.
Low tech will work when all else fails.
Old 07-08-2012, 04:16 AM   #5 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
with irfanview, my printer, and a scale.
http://ecomodder.com/forum/showthrea...dge-22354.html
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 07-08-2012, 11:08 AM   #6 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Print it out to 10% of your vehicle height, draw a 1cm grid over it, then draw a 10cm grid on a piece of plywood and trace it.
For instance, I am doing a scale model for a three wheeler project. The real car will be 3200mm long so I printed out a profile view 320mm long to begin making the model. It's a really simple technique which I reversed from full size in Photoshop to scale size in real life.
The Following User Says Thank You to Sven7 For This Useful Post:
aerohead (07-09-2012)
