Old 01-29-2011, 08:22 PM   #21 (permalink)
Weather spotter: how did you attach the full-wheel discs? My Highlander as spoked steel cast wheels.
Old 01-29-2011, 08:25 PM   #22 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I have steel wheels so I just drilled and tapped them. then I used three bolts on each pizza pan.
The Following User Says Thank You to Weather Spotter For This Useful Post:
Buddy (01-29-2011)
Old 01-30-2011, 02:57 PM   #23 (permalink)
While I like the front and side air dams, I am concerned about rising temps for a) the engine, b) the auto transmission, and c) the exhaust system. I have a ScanGuageII installed, and it does read the engine temp, but not the temps for the other two. Any thoughts about this issue?
Old 01-30-2011, 09:24 PM   #24 (permalink)
Silver EP3 - '02 Honda Civic Si
As always YMMV.I don't use my brakes much, I have a manual, and I try not to. If you minimize brake usage, i doubt you will have an issue...
Old 01-31-2011, 12:34 AM   #25 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
What kinda vehicle do you have?
You could use an electronic meat thermometer to monitor temps in those areas.
Ever since I put my full belly pan, blocked 67% of my front grill, dropped my air dam 6½" lower and slapped on 11" side skirts...I haven't detected any rise in temps. I am looking to isolate my exhaust system with some aluminum sheeting or tubing.
You can git an auxiliary transmission temp gauge and plumb that in.
