02-25-2012, 02:17 PM
ECOModder
RAV - '13 Toyota RAV4 XLE AWD 90 day: 27.56 mpg (US)
Geo Metro Alternator Circuit Question (for disconnect switch)
I am currently in the process to put a switch inline with my field circuit wire.
Now, I have a 92 Metro and one wire is B/W and the other is W/R.
I know W/R is for the Lamp and the B/W is for the ignition.
Here is thing problem/oddness.
If I disconnect ONE wire, it doesn't matter which one, the alternator still out puts 14+ volts.
If I disconnect both, then it does not. I find this odd and different from my other alternator mods I have done.
Has anyone experienced this? Before I create a shut off/on circuit for both wires, I want to make sure I am not over looking something.
Thanks.
3585 pounds of twisted steel.
Recreational | Active | Vehicle | 4x4
...scratch that... AWD
02-27-2012, 03:47 PM
Afraid I can't help on this one. I never went into the schematics for my Firefly.
You've done this to other cars?
If nobody else chimes in, please come back and post what you learn.
02-27-2012, 03:50 PM
ECOModder
NP. I have done this before. I am currently running a 2 relay / one switch setup. One relay per circuit.
I think I have a sticky relay, but seems to be a working idea. I still need to tinker on it some more when I get more time. I will be more than happy to post my findings.
02-27-2012, 03:55 PM
You mean you've implemented 2 relays + one switch on the Metro?
Any reason we couldn't just go with a double pole, single throw switch?
02-27-2012, 05:59 PM
ECOModder
Got it figured out with some help over at the Geo Metro Forum. Alternator Wiring
Apparently it is a self sustaining field. I tested it and sure nuff...
Why not a two pole? Well, just my personal choice I guess. I felt safer with relays, and I couldn't find a "cool" two pole switch that would blend into the dash. I am weird like that...
The Following User Says Thank You to Mr. Previa For This Useful Post:
03-09-2012, 07:39 PM
ECOModder
The saga continues. Today I was going to start some driving with the alty off. Now, the alty turns on (starts charging) by itself if I give the Geo enough gas. So strange. My fix will be to put another large relay (probably a starter relay) on the positive charge cable going to the battery. That is the last link. (I think...)
03-09-2012, 09:45 PM
ECOModder
Denso Alternator Wiring
UPDATE.
Ok, here is what I found out about the 3 wire Denso alternators.
The Terminals.
- "IG" goes to the ignition switch, and functions to tell the alternator when to start charging.
- These alternators will start producing current even when just the battery/heavy-duty connector is used.
- "IG" provides power to start the alternator using lower rpms.
This would explain why even though the IG and Lamp circuits are disconnected, the alternator will start charging when I give it a little gas. (increasing the rpm's)
If anyone has any facts to add, please do so.
I hope this will help others when adding a control switch like I did.
My setup is this: - One 30 amp switch to control 3 relays
- Two, 40 amp relays for the IG and Lamp circuits (yes, overkill, but that is the way I roll)
- One, 100 amp starting solenoid to control the battery charging wire
03-10-2012, 01:18 AM
Too many cars
Good info!
Make sure the starter solenoid is rated for continuous duty. I think Surplus Center - Hydraulics, Engines, Electrical and More has them.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
