05-25-2014, 03:13 AM
Furry Furfag
P/S Delete on a '00 Corolla?
I want to either remove or disable the PS on the Green Goblin, I mostly do highway/freeway driving so I don't really need it. I heard there is a way to remove the fluid without harming anything, and remove some belt so the pump isn't running? Idk I'm confused and would love some advice. If it's possible, I would like a solution that would allow the ability to get it working again for re-sale without to much work.
Oh also, I would like to get a hotter sensor for my radiator fans, where would I look for one?
05-25-2014, 04:25 AM
I believe that you need to reengineer this:
http://ecomodder.com/forum/showthrea...elp-10688.html
If you have one serpentine belt instead of individual belts, you would need to figure out a new route and a new belt.
I have never heard of Aerolla, but in his garage, it says he deactivated the power steering on his 1997. I looked at about sixty other Corollas and nobody else even mentioned this modification!
05-25-2014, 04:47 AM
Furry Furfag
Oh wow... Well Nvm then lol. Oh well it was worth asking anyway.
05-25-2014, 05:17 AM
It never hurts to ask--unless a woman will slap you!
05-25-2014, 01:15 PM
Why don't you try buying a MR2 Spyder tensioner and serpentine belt? The MR-S has EHPS, no belt driven PS pump. I think that's all you would need to do. Just route like it is on the MR-S.
05-25-2014, 01:25 PM
herp derp Apprentice
05-25-2014, 01:33 PM
If you really want to save money, a lot of people part out blown 1ZZ/2ZZ engines (and there are a lot of blown engines), you can get a pulley really cheap from them if you browse the forums.
05-25-2014, 09:26 PM
Originally Posted by 2000mc
That one is $75
$44.37 Toyota Parts - Toyota Parts Superstore
You can purchase one from Autozone or O'Reilly for much less.
05-26-2014, 12:24 AM
#9 (permalink)
If you can do the p/s delete for $50 to $100 and pick up 2 or 3 mpg it would be worth it.
