Old 08-08-2021, 03:07 PM   #71 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Coincidentally, I had this queued up last night and I'm listening right now:
Building a BETTER attic - Unvented + Conditioned attics 101
We've had unvented, insulated attics for decades in Europe
Conditioned when folks wanted the extra living space
And we generally don't use metal roofs
Though they're getting more popular in double roof set-ups with a little updraft-ventilation void between 2 roof layers (one watertight, the other insulated)
Old 08-08-2021, 04:05 PM   #72 (permalink)
A conditioned attic is inferior to an hemisphere with an oculus.
http://jonmacken.com/images/interior%20[skylight].JPG
Going by past ice ages and interglacials (warm periods between ice ages), we're nearing the temperature peak of the current interglacial period.
But we're not quite there yet.
That's like driving with you eyes fixed on the rear-view mirror. Meanwhile the Beaufort Gyre spins up North.
Housed in the western part of the Arctic Ocean is the Beaufort Gyre, whose growing reservoir of freshwater is shrouded in mystery. In recent years, this increasing freshwater content (FWC) has been the focal point of many studies, particularly those concerning coupled ocean-atmosphere dynamics. The majority of the Arctic’s freshwater content resides in the Beaufort Gyre. ... If, as is speculated, as the Arctic Ocean becomes a heat collector resulting in a low pressure, counter clockwise rotating system, the Beaufort Gyre can be expected to follow suit and send the fresher water outward to be captured by the transpolar current. This could well bring up the saltier, slightly warmer Atlantic water which lies under the floating, fresher Arctic water.
[snip]
The seasonal cycle of freshwater content does not only concern mechanical (Ekman pumping) processes, but thermal (ice formation) processes as well. The Beaufort Gyre contains a mean volume of 800 km3 of frozen freshwater, or sea ice, based on a mean ice thickness of 2 meters. ... The maximum in freshwater content released into the ocean waters coincides with a maximum in wind stress curl (i.e., a minimum in Ekman pumping), allowing for a high volume of freshwater to seep into the Arctic Ocean circulation. This rapid influx of freshwater into the Arctic circulation forces a large volume of freshwater to outflow into the North Atlantic basin, affecting the Atlantic Meridional Overturning Circulation.[6]
Old 08-10-2021, 01:45 AM   #73 (permalink)
Originally Posted by euromodder View Post
The big thing CNG has going for it, is that you can replace it with biogas from waste and synthetic gas made from other sources (like Audi's syn-gas plant using windmills to make NG from CO2 and water)
And let's suppose a dedicated-CNG engine with direct injection appears, it would not require the GPF nowadays fitted to some gasoline-powered engines which resort to direct injection too. But anyway, CNG still makes more sense with port-injection.
