Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
View Poll Results: Is this idea good or bad?
Pure genious, you have saved the world! 0 0%
Terrible idea, the world is now more stupid because of it! 0 0%
Voters: 0. You may not vote on this poll
Old 10-18-2020, 06:03 PM   #1 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 207.11 mpg (US)
Send a message via MSN to jakobnev
The greatest idea ever, or the worst idea ever? ("Free" BMS)
NiMH batteries are known to not need balancing even in series packs. Liion and LTO chemistries are known to need balancing.
Here's the idea: Use NiMH batteries in parallel with other batteries to keep them balanced!
When building a Liion pack, use three NiMH cells for each Lithium cell, or two for each LTO cell.
"But NiMH aren't free!"
No, but you get to use their capacity too! The BMS:ing they provide is free!
Stupid crazy - or crazy stupid?
Old 10-18-2020, 06:15 PM   #2 (permalink)
Above my pay grade. Cell voltages the same?
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 10-18-2020, 07:56 PM   #3 (permalink)
Efficiency Aficionado
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 44.13 mpg (US)
I assume a BMS is designed and implemented based on the battery chemistry. Mixing battery chemistry sounds like a daunting task given the particularity and optimization for each battery technology.
What about energy density, discharge rate and operating temperature ? They all differ based on the chemistry. You would potentially be faced with a big compromise and possibly operate at reduced overall capacity.
Old 10-18-2020, 11:55 PM   #4 (permalink)
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
Erm. NiMH batteries absolutely do need balancing. Top balancing is the easiest way.
Old 10-19-2020, 03:55 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
House of Tudor
Team Mazda
Plug-in Hybrids
NiMH is about 1.1-1.4v so 3x for Liion is 3.3-4.2v and 2x for LTO is 2.2-2.8v.
It needs to happen, but it does so automagically when the pack is kept full, no external cirquit needed.
The Following User Says Thank You to jakobnev For This Useful Post:
freebeard (10-19-2020)
Old 10-19-2020, 04:34 PM   #6 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Would be cheaper to buy a BMS. And/or one of the new(ish) active balancers. They're both pretty cheap...you couldn't buy components to makeshift your own for what you can buy one ready-to-go for.
