Old 07-10-2009, 11:23 PM   #1 (permalink)
01 Insight - '01 Honda Insight DX
90 day: 67.82 mpg (US)
Subaru Justy Gear Swap?
Hello all I am looking for information on gear swaps for a 90 Subaru Justy.
What I have found so far is that the 87-88 transmission will bolt in and give me a bit better gearing but it still not all that great.
I also found this site on using a second gear in the place of a fifth to bring the ratios even lower. Modifying Gears for Taller Overdrive
though I don't have a friend with a shop anymore so I'm not sure that's an option at this point.
Any one know of options for Gear Swaps for Subaru Justy's?
Old 07-11-2009, 02:06 AM   #2 (permalink)
some information on the justy is on this Wikipedia page:
Subaru Justy - Wikipedia, the free encyclopedia
using those numbers with the stock tire size puts 60mph at about 3600 rpm with the second gen transmission and 3400 with the first gen transmission
( Subaru Justy Forum - Manual Gearbox Teardown/Interchange )
the place that pointed me to the site on using the second gear as a replacement 5th noted a drop from .675 to .590 which would get me to about 3150rpm at 60mph.
I would love to get that number down by another 500rpm at least. My plan is to go all out with mods. Including a boat tail, wheel skirts, undertray....
Old 07-11-2009, 10:34 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Yeah, those kei cars have some crazy gearing, so hopefully you can knock it down a bit. Looking forward to seeing what you can come up with
Old 08-19-2009, 09:21 PM   #4 (permalink)
90 day: 51.82 mpg (US)
We haven't seen many Justy owners around.
(They're not actually Kei cars, Ben - about the size of a Metro.)
Are there no dedicated Justy forums where you can get the specifics on regearing your final drive or 5th? That'd be my first plan.
Old 08-19-2009, 11:33 PM   #5 (permalink)
I have found one Justy forum that had some info on the gearing and even doing a swap. Though the only guy I know of that was actually going to try and do it ended up just swapping the tranny from the 87/88 into the newer car to lower the 4th and 5th gear. as for the final drive, I haven't seen any info on doing a swap for it.
I found that I can fit 165/65r14 tires on the car and I am hoping to get a set of potenza re92s for it unless there is a better lrr tire now?
Good news is I have the car running now, needed an exhaust valve and then it had a clogged injector. Still need to replace the distributor on it to fix a CEL code but its getting there.
justy, subaru
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 06:20 AM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Geo Metro XFi cam swap How To Johnny Mullet DIY / How-to 13 01-31-2012 09:05 AM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Is there a better use for first gear? Oval_Overload EcoModding Central 24 07-06-2009 09:52 AM
