Old 03-11-2009, 02:27 PM   #31 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Ok, my bad... I shouldn't have tried to post anything in as little as 2 minutes. I think the graphic you guys are looking for is this one.
I will make my argument again, but this time I will try to make more sence (although I am posting quickly)
I will equate #20 to a grill block blocked from behind; Cd 2.30. Is this right? No. #20 is taking into account the separation around the edges which pushes up the Cd, but we will say this is conservative.
I will equate #18 to a grill block blocked from the front; Cd 1.98. Once again it's taking separation effects into account that are not there on a car, but once again, it's conservative.
I will equate #14 (or #13) to Aerohead's redesigned truck nose or the Aerocivic's redesigned car nose, where the shape just gets redefined; Cd 1.16 (or 1.20). This is where you see the big gains.
Between #20 without edge effects and #18 without edge effects, you will be hard pressed to see a difference, since you are talking about a 15% difference on maybe 1 or 2 square feet on the front of a car. Reshaping the nose will make a big difference, but some don't like the idea of losing the auto's original sporty looks.
This is what I was trying to say. I chose a bad analogy, saying that a flat plate like #7 Cd 1.17 would slow you down less than #9 Cd 1.42, but would slow you down all the same. Here the difference is about 20%, and in the overall size of the openings we have on our autos vs. everything else that's going on, it's going to be hard to see the difference.
Old 03-11-2009, 04:47 PM   #32 (permalink)
Cogito Ergo Ecomod
davidgrey50's Avatar
Dobbin - '04 Dodge Dakota 3.7 V6 A/T
Winkosmosis - Yes, racing cars commonly vent a front-mounted radiator through a hood vent - check out a Ford GT40 or most any racing car. If you look at the flow diagrams here and there on EM you'll notice that most cars have a huge high-pressure area right at the nose, and a strong low-pressure area just aft of the leading edge of the hood. Put the intake in the high-pressure area and the outlet at the low-pressure area, and seal up that underbody!
The low pressure over the front of the car was more-or-less discovered by Bruce McLaren in the early 60's when he was testing a racing car. Someone hadn't fastened a flap and, to his surprise, rather than being held down by the airstream, the flap lifted more and more as speed increased.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 10:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 01:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 06:16 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 07:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 04:09 PM
