Old 04-23-2010, 05:43 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
1994 Suzuki Swift Sedan Coast Down (Phase II)
You may have seen my earlier post, Suzuki Swift (1994 Sedan) Coast Down Numbers, where I reduced my Cd from 0.32 to 0.28 (a 12.5% reduction). I took things a bit further this time, adding a SedanKamm (the beginning of a boat tail). I did some tuft testing to see if flow is attached, and did some coast down testing.
I built it out of a 4'x8' sheet of coroplast that I had gotten a couple Novembers ago. It is 4' long at it's longest, over 6' wide, and made out of one piece. The back is supported by a 2x6 and the windows are made out of some very thin very clear acrylic. The acrylic is too thin to be used as a grill block (as we found on the Prius, rocks just punch holes in it), but it seems to have done a good job as windows (other than the reflectivity). The windows would be better bigger, but this was all of the acrylic I had left. It would also be better with a dark, non-reflective interior, but this is just a prototype. For the most part, everything is held in place with duct tape, other than the 2x6. No holes were punched in my car's body.
The tuft testing showed a couple things, first, there IS attached flow on the SedanKamm . Second, the AeroSpike Mirror Deflector I had made does little if anything, so I took it off. It was good for starting conversations, but I have something new for that .
The configuration would be the same as the previous coast down, except windows up, both mirrors in stock configuration and folded out, and the addition of the SedanKamm.
The coast down testing shows that I am now hovering somewhere south of Cd = 0.245 (another 12.5% reduction), or around where the Prius or original Insight would be. Funny, more or less the same shape, more or less the same Cd... This is the effect I had predicted, seeing as how over 4 square feet is cut off the trailing edge of the car (about a 20% reduction, and I knew I couldn't take full credit for the reduction). I did 5 bi-directional runs on a very flat stretch, and this time I had an automated GPS logging program catch my speed on ~1sec intervals.
Here you can see it along side our Prius, first from an angle, then a comparison of the trailing edges. The angle for the SedanKamm was picked by the height of a 2x6, and it seeming to be about the correct angle. You can see how close it matches the Prius.
The Following 6 Users Say Thank You to wyatt For This Useful Post:
Bicycle Bob (04-23-2010), California98Civic (06-16-2011), ChazInMT (08-28-2010), Nevyn (04-24-2010), Piwoslaw (04-24-2010), Xist (12-13-2017)
Old 04-23-2010, 05:58 PM   #2 (permalink)
swift
Wyatt,I've been working a few months on an aero comparo study.One of the cars I put under the 'Template',was the 2nd-gen Prius,and with it's spoiler,was quite close to the 'curve'.
Looking at your photos I can only say,that you're doing exactly what will show at the pump and suspect your numbers are dead on.
It looks great! And 'tasty'! Appreciate the heads up.
Old 04-24-2010, 01:44 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Awesome!!
Great job, Wyatt
That SedanKamm changes the shape of the car beyond recognition!
This may have already been covered in another post somewhere, but:
  1. Do you have a full bellypan?
  2. Why don't I see wheel skirts?
Those two things could help get quite close to Cd=0.20.
Old 04-24-2010, 01:48 AM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
wyatt -
Wow!
CarloSW2
American Solar Energy Society
Old 04-24-2010, 07:17 PM   #5 (permalink)
I only had one full sheet of coroplast left, so it was either a full belly pan or a SedanKamm, I figured this would have the bigger impact. I just haven't had time to make side skirts. Both are on the list of "to dos".
Old 04-24-2010, 08:16 PM   #6 (permalink)
Also, I forgot to mention that I still have access to my truck through my fold down back seats. It's not perfect, but it works.
Old 04-24-2010, 09:17 PM   #7 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
Looks nice!
How did you get the clean cross-grain folds in the Coroplast?
Old 04-24-2010, 09:29 PM   #8 (permalink)
Cross grain bending is accomplished by using a straight edge to make a very straight score on the back side. Then leave the straight edge in place to make the fold. Just be careful to only SCORE the coroplast and not to CUT it. A lot of planning goes into making a complex geometry work the first time, but making some drawings of what you expect the piece to look like, andmaking the piece on sight help a lot.
blownb310 (10-03-2011), California98Civic (06-16-2011), ECONORAM (12-26-2010), Piwoslaw (04-25-2010), thatguitarguy (04-24-2010), Weather Spotter (08-13-2010)
Old 04-25-2010, 11:39 PM   #9 (permalink)
Some MPG results for you...
I have made several trips to and from Wisconsin with Suzi, so I thought I would make a comparison of the before and after SedanKamm results. Before: over 1200 miles averaging 48.0mpg; after: over 1800 miles averaging 50.9mpg. This is roughly 6% better gas mileage, which corresponds quite nicely to the 12.5% drag reduction experienced with the addition of the SedanKamm (the rule of thumb I have heard [and seen] works, is for every 2% Cd reduction you get a 1% FE benefit).
The Following 3 Users Say Thank You to wyatt For This Useful Post:
aerohead (05-11-2010), ECONORAM (12-26-2010), MetroMPG (08-18-2010)
Old 05-10-2010, 10:45 PM   #10 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Wyatt,
dang nice job!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
boat tail, coast down, sedankamm, suzuki swift
Suzuki Swift (1994 sedan) Coast Down Numbers wyatt Aerodynamics 18 11-24-2009 04:03 AM
The Suzuki Swift is still a super sweet car! SVOboy General Efficiency Discussion 15 11-22-2009 11:17 AM
SUZUKI - Bring the Swift to the States!! FunkSkunk EcoModding Central 11 10-19-2008 10:41 PM
92 Suzuki Swift Project Roman EcoModding Central 42 08-25-2008 08:38 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
