Old 08-04-2008, 06:18 AM   #11 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
on my car (wich has the lightest engine available for the model) part of the top grill is backed of from the factory with a flimsy plastic insert that blocks of two rows of grill as well as the back of the opel logo wich would also allow quite some air in.
also the bottom grill wich consists of 2 openings has the bottom one blocked, although i can't see if it's part of the bumper molding or a separate piece.
anyway, for the top grill it's is almost a 50% block with a cheap looking plastic bit that snaps in place behind the grill.
although this might very well be the cheapest bit on the car, the fact opel cared enough to put it there should mean it would deliver a measurable improvement wich could be marketed as better economy and emission figures (the later became more strict around the time the car came out).
personally i think the difference, between grillblock vs no grillblock is far greater than between internet and external.
a smooth external block would be best, but in the real world i think an internal block might be easier to make without altering the looks of the car, and still be just as effective.
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 08-04-2008, 11:45 AM   #12 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I feel the same way, I blocked the one on my wifes car from the rear.
SWMBO doesn't want any "Ugly" alterations to her vehicle.
So far everything I've done has the "appearance" of being stock.
http://ecomodder.com/forum/showthrea...over-1707.html
Some stuff helped noticeably and some didn't.
But it is all still there (so far).
Schultz
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Front plate alternatives pasadena_commut Aerodynamics 8 07-12-2008 10:30 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 10:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 10:14 AM
Front VS Rear drive on electric bennelson Fossil Fuel Free 18 02-03-2008 03:10 PM
