Old 06-24-2009, 07:04 PM   #41 (permalink)
Driving the TurboWeasel
The fasteners are properly known as toggle bolts.
Toggle bolts along with some washers underneath the screw heads to keep from damaging the plastic.
2012 Chevrolet Cruze Eco 6MT
Old 06-25-2009, 11:17 PM   #42 (permalink)
An interesting tidbit is how my car is staying nice and cool now with 3/4 of the grille blocked. It's almost like the block is forcing more air into the radiator.
I'll know tomorrow when I take another weekend trip.
Old 06-26-2009, 11:23 AM   #43 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Maybe it needed a bit of the upper open to push flow up from the lower grilles? Relieving exess stagnant air in the large void up there? Kind of like scavenging in an exhaust system? http://en.wikipedia.org/wiki/Scavenging_(automotive)
1996 Pontiac Bonneville SE 3.8L V6
Old 06-26-2009, 06:21 PM   #44 (permalink)
I don't know. All I know is that my car is staying insanely cool. Even in heavy city traffic. At the heat of the day. And it wasn't doing this before with half the grille blocked off. Then it would kick in the fans all the time. I've never seen it get above 184 (fans on at 186) before I get moving again.
It works.
The next tank might be a bit off since I'm dumping in 2 bottles of Techron. 18 gallon tank means 1.5 bottles according to directions, but 2 are going in for good measure.
Old 06-26-2009, 06:37 PM   #45 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
Originally Posted by QuickLTD View Post
The Civic has it relativley small sized radiator offset to right am I correct?
Correct.
aerocivic.com
Old 06-26-2009, 07:57 PM   #46 (permalink)
It works.
Not sure if adding extra for good measure is a good idea. You're supposed to change your oil after you do it too.
The block shouldn't improve cooling at a standstill. I could see it helping at speed though. I speculated on that in my thread about the teardrop roof for boxy SUVs. Seems pretty feasible to me.
Old 06-26-2009, 08:02 PM   #47 (permalink)
QuickLTD's Avatar
He is putting the techron in the fuel not the oil.
Old 06-26-2009, 08:16 PM   #48 (permalink)
But the carbon that gets cleaned out would end up in the oil no? I'm going by what people say on Miata.net
Old 06-26-2009, 08:23 PM   #49 (permalink)
QuickLTD's Avatar
Ahh, could be. Blow by with an older engine might do that? Make sure to read that bottle 99LeCouch.
I know a lot of people who use "Seafoam" and they pour half a bottle into the a vacuum line and put half in the tank. In that case you do need to change the oil.
Old 06-29-2009, 01:31 PM   #50 (permalink)
The block doesn't improve cooling any at a standstill. Once I'm moving it really takes over.
The Techron goes into the gas. And you don't have to change the oil after you're done. It sends all the gunk down the tailpipe. What's left over can affect your oil, but only if you don't change the oil for 20,000 miles.
I also Auto-RX'ed this engine, which cleaned it out nicely. I don't think blowby is a problem with the 66k miles my car has on it. 35k of that I've put on the car in the past year and a half. And my grandfather had the car before me, and he drove like I do now. AKA slowly and gently.
Gasoline expected to remain cheap this summer Frank Lee The Lounge 0 04-14-2009 04:43 PM
grille blocks, fan kicks on malibuguy EcoModding Central 12 01-20-2009 02:04 PM
Temperature controlled grille block Piwoslaw Aerodynamics 19 11-09-2008 11:24 PM
Grille block: front or back and top or bottom? 07b2300 Aerodynamics 11 07-07-2008 11:19 PM
Full Grille Block: Upper Grille DifferentPointofView Aerodynamics 12 02-28-2008 11:14 AM
