Old 07-29-2009, 01:29 PM   #1 (permalink)
Looking for those MPG's
HAI with a radiator?
Has anyone considered using a computer radiator to help warm the air on a HAI setup? I was thinking of diverting some of the hot coolant into the computer radiator which would be placed at the opening of the HAI so the air would get pulled through the radiator fins. This may have been done before by someone on here, so some advice or just a link to the thread would be appreciated.
Thanks,
Jason
Old 07-29-2009, 01:30 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
You could just pull the air through the normal radiator...unless you were thinking of something hotted than that?
Old 07-29-2009, 02:22 PM   #3 (permalink)
Well, I wasnt sure if there was any correlation with higher temperatures leading to better fuel gains. Has anyone done any studies on the optimal temp of the intake air?
Im assuming that hotter would be better, but this could easily be a case of quickly diminishing returns.
Old 07-29-2009, 02:32 PM   #4 (permalink)
S E A R C H F U N C T I O N
Old 07-29-2009, 03:37 PM   #5 (permalink)
I have used the search function and skimmed through most of the HAI threads, but I cant find anything showing anyone who has actually done this mod. But thanks for the help Frank
Sealing the areas around the radiator Daox Aerodynamics 13 06-09-2009 04:28 PM
Radiator block + EOC vs. heat soak some_other_dave EcoModding Central 6 05-16-2009 01:02 AM
S10 radiator fan changes? bennelson EcoModding Central 29 12-29-2008 07:54 PM
5 min radiator block aeromod bennelson Aerodynamics 20 02-24-2008 10:40 PM
Ecomodding Smaller Radiator of Choice? XFi EcoModding Central 2 01-22-2008 04:53 PM
