Old 03-14-2012, 10:28 PM   #1 (permalink)
95 chevy suburban
thinking of building a building a suburban into a mileage rig.
bought a 95 today for 300 bucks - has a smashed front fender.
car is 72 inches - figure I can lower it 6 inches pretty easy. Thinking about tapering the sides of the car at the back.
Thought would be to remove one of the doors on the very back of the car, slice the top, and bring the sides together.
Anyone ever seen sucha thing?
Old 03-15-2012, 09:28 PM   #2 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
[Sarcasm] I think for my next project, I'll get a Metro clone and build it to 400 WHP. I might give it 4WD also; would be a great winter car. [/Sarcasm]
OK, OK.
But I think a Suburban has so much going against it mpg-wise, I can't see how it would be a good starting point. Unless of course you NEED a Suburban for it's massive capacity or some other quality it has. In which case, I think I'd just give it a tuneup and pump up the tires and drive it only when absolutely necessary.
Coast long and prosper.
Old 03-15-2012, 09:57 PM   #3 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
i think you gotta better chance at modding a pickup, i beliveyou own a big diesel!? so that would be better than the suburban
Old 03-16-2012, 01:07 PM   #4 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I've never seen one but if your body work skills are up to it, you should get good results.
For a $300 steal, how bad could you foul it up?
An aerolid on a pickup that tapers in elevation view is one thing but tapering in both plan and elevation - Hucho would be proud.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 03-16-2012, 01:09 PM   #5 (permalink)
Big Dave's Avatar
There are rumors that GM took a 'Burb and put a 6.2 diesel, a stick shift and 2.73 gears and got 30 MPG out of it.
See the 62-65dieselpage.com.
4" Slam
Old 03-16-2012, 01:42 PM   #6 (permalink)
Or you could plug numbers into the performance calculator, changing only Cd value, and see what you might get.
