You did include the part number, I was referring to the bontrager universal derailleur flexible cable. I ended up ordering a 1.3mm x 2000mm one, enough for two cars.
I understand the concerns for this type of mod. I'm in the camp that wants it solely for throttle lock for long distance, exclusively highway-only "dumb" cruise control. My version will incorporate worst case scenario tweaks such as a flexed open end (bent cable with no cap) that will hold tension but will unthread the drilled hole if yanked in an emergency. Also, my car is 5-speed so going into neutral cuts power and at an estimated 10-15% throttle needed for sustaining highway speeds there is little worry of hitting high RPMS. Finally, back when Toyota's infamous runaway Prius recall was taking place, a popular car magazine drove two cars to 60 mph (one an economy sedan, the other a Stage III Mustang IIRC) and simultaneously floored both the throttle and brakes. Neither car could overpower it's factory brakes and did come to a complete stop (albeit at a longer distance than normal). Point being, 100% > 15% throttle so there's little concern there. Finally, $16 mower mod vs. $3XX for aftermarket cruise control. We're a frugal group by nature. I'll report back in a few weeks once I install everything.
Mak
