06-01-2023, 11:40 AM
High Altitude Hybrid
How do you find a good mechanic?
- The first mechanic I went to I needed a clutch replaced. After that the car's alignment was so bad it would bounce all around and by the time I figured it out (I was new to owning a car) the tires were to the metal bands. He fixed the alignment for free, I ended up buying tires from somewhere else.
- When I bought tires from another shop I went with brand new tires. But when looking at the tires afterwards I found that they were two different brands, not at all the same tires all the way around. I complained but they refused to do anything about it.
- My break lights went out and changing the bulbs and brake switch did nothing. It turns out that the 1984 Toyota Corolla I had also had a brake light controller in the trunk. I took it to a Toyota dealer and they took several hours and never fixed it and charged me $200 (this was in the 90's). I ended up asking around and found I could just get the part at a junk yard for $10 and swap it out myself, which I did.
- Another alignement in another car and they changed out some bolts that hold the shocks onto the steering knucles to do the alignment, which was standard proceedure on a 1985 VW Golf. But they used cheap week bolts that a week later had stripped themselves and were coming out! I didn't go back and will no longer go back for anything.
It seems everytime I go to a mechanic I have a bad experience. I'm just not sure who to trust. How do you find a good mechanic and keep a good relationship with him or her? I'm to the point I'm aligning my own cars with strings and levels and chaging and balancing my own tires. But there are things I just can't do anymore. I can't fix the radio in my Avalon. I can't change the brake fluid properly. There are probably a lot of other things I can't do.
That and there are things I would want the mechanic to do, but they have their own policy. Like when I want to use an OEM dealer part but the shops around will only install parts they buy from NAPA or Autozone. Sometimes I ask for something and they're like "Why would you want to do that? We never do that. Maybe try somewhere else."
Where do I go for help? SMA, Shadetree Mechanics Anonomous?
The Following User Says Thank You to Isaac Zachary For This Useful Post:
06-01-2023, 10:29 PM
Growin a stash
Xist will fix it for you.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following 2 Users Say Thank You to ME_Andy For This Useful Post:
06-02-2023, 01:07 AM
DIY
06-02-2023, 03:14 AM
I know DIY might be more of a PITA with some rather modern cars with many bells and whistles which sounded quite like a sci-fi pipedream when I was a kid, and maybe your friends won't be able to indicate you a mechanic you may see as good
06-02-2023, 10:42 AM
Ah the joys of living in a small town with very limited resources and full of gossipy people having time on their hands. One reason I moved to Reno before it got discovered.
I can take the Golf back to the dealer and pay + $2,500 for competent yearly maintenance. Or I can use a local repair house for half that and worry they may be competent on a odd vehicle with weird requirements, or I can crawl around doing my own for the cost of parts. Hint: crawling around now leads to 2 days of forced recovery. Feel your pain about reliable reccomendations.
There are two fixes: move or become very rich.
06-06-2023, 01:27 AM
Finding a mechanic who does a good work at a more reasonable cost might be the most challenging aspect. When it comes to OEM parts vs the ones bought at NAPA or Autozone, as long as they're of a similar or better spec, I wouldn't be so strict about OEM in order to evaluate if a mechanic is good or bad.
06-06-2023, 01:56 AM
But what about parts you've had that the OEM lasted 20 or 30 years but the aftermarket one needs replacing at least once a year?
06-06-2023, 02:06 AM
Then it's a whole different deal. No wonder I said either similar or better than OEM, instead of endorsing someone who goes half-ass. I have already seen a '98 Mitsubishi Pajero which had been fixed in a half-assed way, with some hose that couldn't hold up to the vacuum pressure it had to do.
06-06-2023, 10:21 AM
#9 (permalink)
You can generally buy the OEM equivelant part, but it priced at the OEM price. Most people won't pay that. Also how often do you own a vehicle for 20 years and expect to realistically get another 20 from it? My 2000 f250 might go another 10 or more, but I'm pretty sure I cant drive it then because I will be 80 and getting in it to drive will be really hard.
06-06-2023, 05:47 PM
#10 (permalink)
I know that, but the mechanic won't put it on if I buy the part myself.
Maybe not another 20, but at least another two years would be great if I'm paying out my nose for a repair. Having to bring it back in 6 to 12 months later for the same problem isn't what I call fun.
