Old 06-24-2010, 01:03 PM   #1 (permalink)
Aspiring EcoModder
Eggy - '99 Saturn SL2
90 day: 43.7 mpg (US)
Question Why do some tires have low max sidewall psi of 35
Hopefully someone here can provide some insight.
Why do some tires have such a low max inflation pressure of only 35 psi. My Pirelli Cinturato or Pirelli P3000 Cinturato, can't remember the exact name. These were ~$80/tire at Discount Tire for 185/65/R15 and they all have an 85k mile warranty. I don't consider these the "cheapy" brand. I would have expected Pirellis to have a minimum max of 44 psi. Essentially, I want to inflate my tires to at least 40 or even 44 psi.
Old 06-24-2010, 02:06 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Well, I'm not entirely sure, but I sent a quick question to the Pirelli tire people to try and figure out by what criteria their tires came to this rating, so we'll see if we can get a response.
Old 06-24-2010, 02:44 PM   #3 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
My uneducated guess would be that it's due to the construction of the carcass of the tire. From what I understand, the inner layers and belts is the backbone and carries the stresses and provides the strength of the tire.
But it will be interesting to see if Perelli responds.
-Terry
Old 06-24-2010, 02:58 PM   #4 (permalink)
Why wait for Purrelle?
IIRC CapriRacer has already explained it here...
Old 06-24-2010, 04:02 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
My guess is with TC, it's all about sidewall construction, reinforcement, etc.
My winter tires are 185/65R15 and have max sidewall 51psi...
Old 06-25-2010, 11:49 PM   #6 (permalink)
Driving the TurboWeasel
My Pirelli P4's have a max of 44 PSI. They've seen that and some more the 50k miles they've been on my car. Not a problem.
2012 Chevrolet Cruze Eco 6MT
Old 06-26-2010, 03:01 AM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Seems to me the cheapest tires are 35 PSI, the better tires are 44 PSI.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-27-2010, 01:37 PM   #8 (permalink)
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Honda Civic DX
90 day: 41.59 mpg (US)
It's just the way they're made... that's the maximum it is safe to run them at. More expensive tires would probably be safe to run at a higher PSI.
Just remember that the PSI increases roughly 3-4psi when you start driving as they warm up. Heat causes expansion.
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
Old 06-29-2010, 09:44 AM   #9 (permalink)
jusnicho's Avatar
Midg - '99 Hyundai Accent HTCBK
90 day: 37.33 mpg (US)
Landy - '02 Land Rover Discovery II SD
Last 3: 17.44 mpg (US)
Pilot - '05 Honda Pilot EX
90 day: 21.22 mpg (US)
MZDA - '10 Mazda 3 iTouring
90 day: 37.8 mpg (US)
F150-project - '04 ford f150 xl
a lot to do with construction. Some tires are very flexible and your wear pattern will eat the center of the tread on your tires if you over fill.
JusNicho
"Drive it like you're
running outta fuel."
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
hyper inflation: let's cut to the chase ShadeTreeMech Hypermiling / EcoDriver's Ed 50 06-15-2010 06:18 AM
Tires with different max PSI Goldenfrog EcoModding Central 2 06-14-2008 03:42 PM
