Old 02-14-2023, 10:47 PM   #11 (permalink)
90 day: 28.24 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 25.04 mpg (US)
I'm not afraid of hot water heater bombs mostly because I don't even know anybody, who knows anybody, who knows somebody that was harmed.
I did watch the Mythbusters episode though, and that was quite entertaining.
Perhaps the 1st stage of rockets should be steam powered hot water heaters?
Old 02-15-2023, 05:51 AM   #12 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 36.44 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 29.73 mpg (US)
But almost nobody does that, including me.
lol)) doing that once a year.
Old 02-15-2023, 10:22 AM   #13 (permalink)
Usually the case splits and all you get is a bunch of water damage.
Old 02-15-2023, 12:02 PM   #14 (permalink)
Mine is located in the basement, in what I refer to as the boiler room where the furnace also lives. 2ft from the drain, so water damage would only be possible if it split on the side facing the drywall.
Old 02-15-2023, 04:50 PM   #15 (permalink)
Youtube insisted I should watch the video. Turns out I was wrong, I replaced the heating element, not the sacrificial anode.
My heater has no connections on the top, hot at the top of the side and cold at the bottom. And it doesn't have the fancy feature with only one heating element.
Since I long ago raised the bathroom vanity up 2" I could R&R the heater into an insulated box. I already have a manual on/off switch.
One disappointment was he used the term 'dip tube' when one of my new favorites is 'downcomer'.
"If you don't read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed. " someone who was not Mark Twain
Old 02-21-2023, 02:54 AM   #16 (permalink)
I spent 4 years without replacing the heating element of the shower at home, but I don't know how many times my father eventually did it while I wasted my time with my mother staying at her apartment
Last time I had to replace the heater element, which was around 2 months ago, as I wasn't finding the appropriate heater for my shower, I had to compare the one for the 220-volt version to some random 127-volt until I found out one which seemed to have the same size.
Old 02-21-2023, 06:36 PM   #17 (permalink)
90 day: 33.21 mpg (US)
I recommend a magnesium anode, ball valve drain and if it's electric only put a straight element in the bottom, change the magnesium anode every 2 to 3 years.
What do you think about powered titanium anodes with 20-year warranties? Corro-Protec™ Powered Anode Rod for Water Heater, 20-Year Warranty, Eliminates Rotten Egg/Sulfur Smell within 24 hours, Stops Corrosion and Reduces Limescale, Electrical Anode Rod Made of Titanium
