Old 11-01-2014, 10:11 PM   #41 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
That's the joke. My radiator is full of oil.
Air cooled V-dub?
Old 11-01-2014, 10:29 PM   #42 (permalink)
I assume it was a red neck fix to a blown head gasket by filling the cooling system with engine oil.
If its an older vw, those are air cooled, no water there or radiator. I was never into those, but I was the firs gen water cooled ones.
Old 11-01-2014, 10:51 PM   #43 (permalink)
Master Novice
elhigh's Avatar
There's an oil cooler in an air-cooled VW, it meets my criteria for a radiator. The add-on ones you might install on an enhanced engine - or just to improve on the feeble original - look the part even more.
Old 11-02-2014, 01:31 AM   #44 (permalink)
elhigh -- Yup. The weekly driver has a stock 1600, except for a billet aluminum distributor full of Ford parts.
The engine I hold in reserve is a stroker 1776 with an aluminum case and big-valve heads, that was going to go into the van I sold. It has a Type IV cooler in the doghouse.
Others I have had had braided stainless hose run all over the engine compartment.
Cobb -- Water is corrosive and best kept away from machinery, while the lubricating film of oil is fundamental to things even working at all.
I'd like to see a VW or Porsche boxer that is dry-sumped and then carries the external oil tanks in large corrugated copper valve covers. The oil would return down the pushrod tubes. I think it would be quite effective.
Old 11-02-2014, 12:14 PM   #45 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Sounds a neat idea.
Is there enough room in the valve covers area to do that ?
Old 11-02-2014, 01:29 PM   #46 (permalink)
Could be. The bigger problem would be that the solid valve lifters require regular periodic adjustment.
It showed up in a design for a front-engined Lakester race car, with no oil cooler for less internal air drag.
