Old 08-22-2016, 11:49 AM   #41 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
I kept an eye on the battery for 10 hours, and made this plot:
Needing to go to bed, I put the grid charger on a timer to run for 4 more hours, and the cooling fan to run for 5 more hours. I don't know what the final voltage ended up being, as I wasn't awake, but after 10 hours it was probably close, at 176.3v. In similar weather, my Insight's pack generally gets up to 170-173v, and I believe peak voltage is (somewhat) an indicator of pack health, lower being better. Still, I'll see what it does. Maybe I can get that to come down a bit after a discharge cycle.
Old 10-07-2016, 03:20 PM   #42 (permalink)
Cinco The Miata - '90 Mazda Miata
Team Mazda
Sports Cars
90 day: 36.13 mpg (US)
Oscar Wilde - '02 Honda Metropolitan
Motorcycle
90 day: 94.9 mpg (US)
Just bought an 03 Civic Hybrid for my wife. Lots of good info in here. Subscribed
Old 10-24-2016, 08:44 AM   #43 (permalink)
Team Mazda
Sports Cars
Motorcycle
How are you liking the Michelin Defenders? Our HCH will need new tires soonish. The Defenders seem a lot more expensive, then some non LRR tires. Have they made a difference in MPGs in your experience?
Old 10-24-2016, 08:52 AM   #44 (permalink)
Most winter tires are relatively LRR, and I've only had winter tires and the Defenders on this particular car so I don't have a lot of basis for comparison. However, on my Insight the difference between a good LRR tire (Defender, RE92, Dunlop Ensave) vs a normal touring tire can be 10-20%, or as much as 20mpg when cruising at low highway speeds (80 vs 100). The Defenders also last an extremely long time, and seem to have a good tread pattern for light snow. I probably would not put a non-LRR tire on it, regardless of price.
Old 10-25-2016, 08:22 AM   #45 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
I put defenders on mine after going through a new set of B381s.
There was definitely a BIG drop when brand new from my worn B381s, like 5 mpg. The drop after break-in was probably more like 2 mpg. Some, but not huge. I'd imagine non LRR tires would be significantly worse.
Sam
