Old 04-11-2008, 11:10 AM   #11 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
+2-3 mpg to the lifetime average.
I can forward you my Excel sheet if you PM me your e-mail address.
Old 04-11-2008, 02:01 PM   #12 (permalink)
Hello Loory. I own a 2003 Toyota Matrix 5 speed. In my route back and forth to work I have achieved 47 mpg just from driving techniques (without any physical modifications) according to my scangauge (my mileage log doesn't reflect that as the wife drives it normally). I would recommend against a cold air intake. Instead, a warm air intake would be much better suited to getting you better gas mileage, especially with an automatic transmission since you can't pulse and glide.
Old 04-11-2008, 02:08 PM   #13 (permalink)
90 day: 51.82 mpg (US)
Is the '07 Matrix drivetrain the same as the '06 Corolla? I think it is.
If it is, I may be able to get some figures to compare to my dad's car (ie. torque converter lockup speed & mpg, etc.)
Old 04-11-2008, 03:28 PM   #14 (permalink)
03 - 08 Matrix/Corolla/Vibe all use the same engine and trans (except Matrix/Vibe had optional awd).
Old 04-11-2008, 09:21 PM   #15 (permalink)
Canada EM member
Loory's Avatar
Roguee - '09 Nissan Rogue SL AWD
90 day: 27.49 mpg (US)
MetroMPG
The slowest speed i can engage the the fourth speed lock-up is at 37mph. I installed the SGII today and went on the highway for a few milles and at 55mph the gauge say i'm doing 45mpg (US), pretty good, i said to myself "i must be going downhill a little" and i tried the same route back and it was the same. I normally go at 65mph for 35mpg but i'm convinced... As soon as i go further than 55mph FE start to degrade, thanks to the SGII. At 50mph it's even better, good to know!
Old 04-11-2008, 09:27 PM   #16 (permalink)
Canada EM member
Loory's Avatar
thebrad,
Thank you for your answer on the CAI. Was the car much louder with it than with the original air bowl below let say 3000rpm ?
Old 04-11-2008, 09:42 PM   #17 (permalink)
Canada EM member
Loory's Avatar
Hello Daox,
Great to ear from a Matrix owner.
Ya 47mpg is pretty good, what speed are you going to get that number ?
I'm pretty convinced i will hit the 50mpg target on all my trips on highway pretty soon! As long as i keep going very smooth on the gas pedal all the time (bellow 50mph).
I'm surprise to ear that some are getting a better FE with P&G cause i always tought P&G was worse in FE than cruising at the same constant speed, that's good to know.
Old 04-11-2008, 09:50 PM   #18 (permalink)
Canada EM member
Loory's Avatar
Daox,
Have you done the warm air intake mod on you Matrix ? How can we explain that this mod could bring a better FE ?
Old 04-11-2008, 09:57 PM   #19 (permalink)
Canada EM member
Loory's Avatar
Hello H4MM3R,
What king of car is your avatar? The shape must be pretty good for FE. Is it yours?
Old 04-23-2008, 05:36 AM   #20 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
welcome from noob 2 noob. wow ur lucky u can use a scangauge. my car is a 92 and obd1, so it's not compatible.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
