Old 02-23-2014, 01:22 PM   #11 (permalink)
Reverse-Trike EV
Giovanni LiCalsi's Avatar
Ideally I would like an aluminum frame trailer but think that might push costs up a bunch. The composite panels were already the plan but I would like to use prebuilt ones meaning they would be flat. There is a supplier out side of Olympia, WA that does aluminum clad 4'x8'x2" for under $200 each. If I homebuild the panels in place I could do gradual curves but I have not actually tried to build my own. I want to keep the weight under 2500# loaded, preferably under 2000#.
Shouldn't a single axle be better in this application?
You can easily form the aluminum panels and the high-density polyethylene foam boards can be steamed to form into a curved shape. This is much stronger than polyurethane foam board. The foam boards are made in China and are inexpensive. The foam board surfaces can be heated with a radiant gas heater until tacky and then the 3-M adhesive can be applied to bond the aluminum sheets. You will not need much if any framing on the interior because the Inrekor panels act as a monocoque body. This type of construction has been proven on British caravans.
Kind Regards,
Giovanni
http://www.steamcar.net/stanley/fastest.pdf
Old 02-23-2014, 01:58 PM   #12 (permalink)
Welcome to ecomodder.
The camper needs to sleep 3+dog, have standup room, a bathroom, and be all weather.
<2000lb? Define bathroom. Maybe a toilet seat that hinges down on the outside with a privacy curtain?
I posted this in 'Which Trailer shape is better??', but I'll put it here too.
Did you see this thread? http://ecomodder.com/forum/showthrea...ted-26565.html I don't think a Harbor Freight trailer is the best chassis.
Giovanni LiCalsi likes Inrekor. I like Polymetal. It doesn't include insulation, but can be rolled into simple curves.
MetroMPG (02-23-2014)
Old 02-23-2014, 05:25 PM   #13 (permalink)
Dark Egg - '12 VW Touraeg
I don't have the cross bars but could delete the rest as well. I planned on putting the wheels inside the shell but thinking about it probably should make some way of fixing a flat w/o having to drop the whole axle LOL!
I would like actual rv toilet with small holding tanks and a shower above, basically a wet rv bathroom.
Old 02-23-2014, 09:35 PM   #14 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 43.77 mpg (US)
With your size and weight targets, don't be surprised if you end up with a Porta Potti and sponge baths.
Aluminum frame construction is not out of the question. Check www.eaa.org for good info. The construction techniques for a lightweight aluminum trailer are exactly the same as for aluminum airplanes.
22 Maverick: Summer 2022 burned 62.74 gallons in 3145.1 miles for 50.1 MPG.
Old 02-24-2014, 01:03 AM   #15 (permalink)
I will check that out JR, and I do have a buddy who works for the biggest aluminum supplier around CDA metals and another who is a aluminum welder exrtodinare although he has moved to Spokane.
I don't think the weight goals iare unreasonable. Jayco makes this with a metal frame and 20' long at 2650# dry
