Old 11-18-2024, 05:23 PM   #1 (permalink)
Grey Turd - '50 Plymouth Business Coupe Deluxe
New Member looking for hybrid to classic examples
Hi There!
I saw an example on YouTube of just such a project and the build thread link led me to this site! Then I found another one which I had lost the trail on at ClubLexus and it too was here! These are relatively old threads, but i look forward to finally learning from those who have gone before!
I have just completed an EV conversion of a 1961 Volvo PV now EV544. It can be viewed under jclars at DIYelecrtriccar.com build forum.
I am now starting a conversion of a 1950 Plymouth Business Coupe to a hybrid using a 2007 Lexus GS450H I got at a salvage auction.
I am looking forward to diving into this forum!
John
Edit again - first was to learn how to post images from a PC (non URL) Second is which forum would be the most logical for a DIY hybrid conversion?
Thanks!
Lynden, WA
Last edited by jclars; 11-18-2024 at 05:42 PM.. Reason: How do I add images from my PC (non URL)
Old 11-18-2024, 05:41 PM   #2 (permalink)
Which ones did you find? 1946 Chevy Prius Truck? Hybrid Hot Rod 2.0 - The Pria Ghia?
Will the Plymouth be a body swap or a drivetrain swap? Does the GS450H have a driveshaft or electric rear axle?
Old 11-18-2024, 05:47 PM   #3 (permalink)
Hi Freebeard!
I am looking at both options and may not know until I have bodies removed from both cars, sitting side by side. I am leaning toward drivetrain swap however, as I have performed those on ICE transplants before.
It is a rear wheel drive via drive shaft, which was the first determinant in qualifying candidates.
John
Oh - the other example was the Pontiac Firebird which I traced from ClubLexus when he disappeared after not being able to find a Lexus.
The Following User Says Thank You to jclars For This Useful Post:
freebeard (11-18-2024)
Old 11-18-2024, 06:01 PM   #4 (permalink)
Now I see you have to post 5 times to allow image attachments. I can't seem to answer in one post anyway, so it will be easy getting to 5. (Am I there yet?)
The other example I followed from being featured on YouTube was the 46 Chevyota. What I noticed he had done was meld (or rather weld) the unibody to the truck frame rails. This is a real possibility for my build as well and hope to gain insight into how he accomplished that.
John
Old 11-18-2024, 07:02 PM   #5 (permalink)
It looks like I answered my own question about where to post my build thread, so I will meander over to the Hybrid depart, hopefully with enough posts logged in to attach a pic or two.
John
Old 11-19-2024, 08:42 PM   #6 (permalink)
Since this is closest to a current EV bodyswap thread:
With a cab-forward design and a boat tail, this could be viable. Sixteen feet is short for a motor home.
Old 11-19-2024, 09:50 PM   #7 (permalink)
Well, not exactly a body swap, more like a body frame and wrap! Very interesting concept, especially as states are starting to prohibit motorhome/RV sales!
freebeard (11-20-2024)
Old 11-23-2024, 02:01 AM   #8 (permalink)
AFAIK there is no explicit prohibition on motorhome/RV sales.
https://www.sfgate.com/travel/articl...5-19911123.php
But maybe, a retrofit similar to what you're willing to do with your Plymouth may be also suitable to a small RV too
