Old 03-05-2013, 10:35 AM   #11 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
My grille has a sliding block, though it only slides ~10mm because of the power lock motor I used. If you use a cable, then the openings can be wider, allowing freer airflow and/or partial opening.
The only problem I have with it is when I park during a snowstorm and the snow melts on the warm hood, then freezes while dripping down the grille. Ice forms on the outside and in between the sliding elements, blocking them. Of course, this happens only when it is cold, and then I don't need to open the grille often (plus the radiator's heat might melt the ice if it gets hot).
Old 03-05-2013, 04:20 PM   #12 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Piwoaw,
Nice!
Basjoos,
Can you post a link to a photo of your block, or a drawing? I can almost "see" it but not quite. Thanks!
Old 03-06-2013, 08:53 AM   #13 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 65.83 mpg (US)
The openings collect air from below the stagnation point on the front of the car.
aerocivic.com
