Old 09-17-2014, 08:15 PM   #1 (permalink)
fuel conserver
Civic - '99 Honda Civic EX
1992-1995 Honda Civic Specifications
1992-1995
Engine
Type
Aluminum Block and Head
Valvetrain
Sohc 4 valve/cyl.
Displacement
97 cu in./1590cc (EX, Si)
91.1 cu in/1493cc (DX, LX, VX, CX)
Bore x Stroke
2.95 x 3.54 in./75.0 x 90.0 mm (EX, Si)
2.95 x 3.33 in./75.0 x 84.5 mm (DX, LX, VX, CX)
Compression Ratio
9.2:1 (EX, Si, DX, LX)
9.3:1 (VX)
9.1:1 (CX)
Horsepower (SAE)
125 bhp @ 6600 rpm (EX, Si)
102 bhp @ 5900 rpm (DX, LX)
92 bhp @ 5500 rpm (VX)
70 bhp @ 5000 rpm (CX)
Bhp/Liter
78.1 (EX, Si)
68.0 (DX, LX)
61.3 (VX)
46.7 (CX)
Torque
106 lb-ft @ 5200 rpm (EX, Si)
98 lb-ft @ 5000 rpm (DX, LX)
97 lb-ft @ 4500 rpm (VX)
91 lb-ft @ 2000 rpm (CX)
Maximum engine speed
7200 rpm (EX, Si)
Fuel injection
Elect. sequential port
Fuel
Unleaded, 87 pump oct.
Chassis & Body
Layout
Front engine/front wheel drive
Body/Frame
Unit Steel
Gross Vehicle Weight Rating
Coupe
DX M/T: 3,245 lbs
DX A/T: 3,315 lbs
EX: 3,490 lbs (Including EX option package)
Hatchback
CX, VX: 3,055 lbs
DX M/T: 3,090 lbs
DX A/T: 3,210 lbs
Si: 3,270 lbs
Si w/ ABS: 3,305 lbs
Sedan
DX M/T, LX M/T: 3,245 lbs
LX M/T w/ ABS: 3,405 lbs
DX A/T, LX A/T: 3,315 lbs
LX A/T w/ ABS: 3,405 lbs
EX: 3,490 lbs
Brakes
Front
10.3 in vented disc
Rear
9.4 in disc w/ABS (EX Sedan, Si Hatchback, EXa Coupe, Available on LX)
7.9 in drums (DX, LX)
7.1 in drums (VX, CX)
Assist type
vacuum
Wheels
Pressed steel, 14 x 5J (EX, Si)
Pressed steel, 13 x 5 (DX, LX, CX)
Alloy, 13 x 4.5 (VX)
Tires
P185/60R-14 82H (EX Coupe, Si)
P175/65R-14 (EX Sedan)
P175/70R-13 (DX)
P165/70R-13 (VX, CX)
Steering
Rack & Pinion
Power Assist (EX, Si, LX, DX Sedan, DX Coupe w/ Auto transmission) Manual (DX Coupe w/Manual transmission)
Overall ratio
17.5:1 (Power)
19.0:1 (Manual)
Turns, lock to lock
3.58 (Power)
3.88 (Manual)
Suspension
Front
Upper A-arms, lower L-arms, coil springs, tube shocks
21.0 mm anti-roll bar (EX, Si, LX)
Rear
Trailing arms on upper & lower lateral links, compensating links, coil springs, tube shocks
13.0 mm anti-roll bar (EX Sedan)
Acceleration (EX)
0-30 mph
2.9 secs
0-40 mph
4.6 secs
0-50 mph
6.5 secs
0-60 mph
9.1 secs
0-70 mph
12.1 secs
0-80 mph
15.5 secs
0-90 mph
21.8 secs
0-100 ft
3.4 secs
0-200 ft
9.1 secs
0-1320 ft (1/4 mile)
16.8 secs @ 82.3 mph
Standard Equipment, Civic Sedans
DX Sedan includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), Power Steering, 4-Wheel Double Wishbone Suspension, 5-Speed Manual or 4-Speed Automatic Transmission, P175/70 R13 All Season Tires, Coin Box, Beverage Holder, Fold-Down Rear Seatback with Lock, Adjustable Front Seat Belt Anchors, Dual Manual Remote-Operated Mirrors
LX Sedan adds:
Power Windows, Mirrors and Door Locks, Cruise Control, Tachometer, Center Console Armrest with Storage Compartment, AM/FM High Power Stereo Cassette with 4 Speakers, Quartz Digital Clock, Cargo Area Light, Front Stabilizer Bar, 14" Wheels with Full Covers, P175/65 R14 All-Season Tires, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
EX Sedan adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Anti-Lock Braking System (ABS), 4-Wheel Disc Brakes, Rear Stabilizer Bar, Air Conditioning, Power Moonroof
Standard Equipment, Civic Coupes
DX Coupe includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), 5-Speed Manual or 4-Speed Automatic Transmission, Power Rack and Pinion Steering (AT only) Power-Assisted Front Disc/Rear Drum Brakes, P175/70 R13 All Season Tires, Beverage Holder, 2-Speed/Intermittent Windshield Wipers, Fold-Down Rear Seatback with Lock, Dual Manual Remote-Operated Mirrors
EX Coupe adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Power Rack-and-Pinion Steering, Front Stabilizer Bar, 14" Wheels with Full Covers, P185/60 R14 82H All-Season Tires, Power Moonroof w/ Tilt Feature, Body-Colored Dual Power Mirrors, Power Windows and Door Locks, Cruise Control, AM/FM High-Power Stereo Cassette with 6 Speakers ('94 and '95 models only), Quartz Digital Clock, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
Standard Equipment, Civic Hatchbacks
All Civic Hatchbacks Include:
Dual Airbags (SRS), Multi-Point Programmed Fuel Injection (PGM-FI) Engine, 5-Speed Manual Transmission, 4-Wheel Double Wishbone Suspension, Beverage Holder, Split Fold-Down Rear Seatback, Coin Box, Two-Piece Hatch
CX Hatchback Key Features:
1.5 Liter, 70-hp, 8-Valve Engine, P165/70 R13 All-Season Tires, Rear Window Defroster with Timer, Hatch-Open Warning Light, Remote Fuel Filler Door Release, Remote Hatch Release, Passenger Assist Handle, Dual Manual Remote-Operated Mirrors
DX Hatchback Key Features:
1.5 Liter, 102-hp, 16-Valve Engine, Available 4-Speed Automatic Transmission with Power Steering, P175/70 R13 All-Season Tires, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/Intermittent Windshield Wipers, Rear Window Wiper/Washer, Remote Fuel Filler Door Release, Remote Hatch Release, Dual Manual Remote-Operated Mirrors
VX Hatchback Key Features:
1.5 Liter, 92-hp, 16-Valve VTEC-E Engine, Lightweight 13" Alloy Wheels, P165/70 R13 All-Season Tires, Chin Spoiler, Tachometer, Dual Manual Remote-Operated Mirrors
Si Hatchback Key Features:
1.6 Liter, 125-hp, 16-Valve VTEC Engine, Power Steering, 4-Wheel Disc Brakes, 14" Wheels with Full Wheel Covers, P185/60 R14 All-Season Tires, Power Moonroof with Tilt Feature, AM/FM High-Power Stereo Cassette, Cruise Control, Rear Window Wiper/ Washer, Tachometer, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/ Intermittent Windshield Wipers, Body-Colored Dual Power Mirrors
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
The Following User Says Thank You to E.Roy For This Useful Post:
War_Wagon (09-17-2014)
Old 09-17-2014, 10:56 PM   #2 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
Do those weights seems out of whack to anyone else? Thanks for the post though.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 09-17-2014, 11:05 PM   #3 (permalink)
Probably gvwr (gross vehicle weight rating).
regards
mech
Old 09-18-2014, 09:14 AM   #4 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Or there should be a 2 in front, not a 3.
Old 09-18-2014, 09:30 AM   #5 (permalink)
Optima Hybrid - '13 Kia Optima LX Hybrid
90 day: 33.02 mpg (US)
Outlander - '15 Mitsubishi Outlander SE AWD
90 day: 25.17 mpg (US)
No... they are the weight of the car + maximum cargo weight. Basically as heavy as it can be and have what the factory believes is a properly operating suspension.
Edit: ... and it says Gross Vehicle Weight Rating in the section just above the weights. Looks like an errant carriage return.
The Following User Says Thank You to Carbon For This Useful Post:
E.Roy (09-18-2014)
