Originally Posted by 83gs1100g
so who is the vtec-e experts out there? i ask this cuse i think the description is wrong in wiki. i was sure the vx works in 16v mode all the time until you go in lean burn then goes to 12v mode. can anyone confirm this? i think what someone put in wiki is mixing up the 3 stage vtec mode that it runs in 12v mode all the time below 2750 rpms.
wikipedia.org/wiki/VTEC#VTEC-E]VTEC
It has nothing to do with lean burn, its all rpm vtec switch over dependent.
Its technically always using 16v. At low rpm, one only opens very slightly (to promote swirl and fuel pooling), so it might as well be 12v.
Once it reaches the change over (2500 for USDM), to two rocker arms are locked together and fully open. Since you've looked at 3 stage, its the same, just without the extra high lift rocker.
If you search youtube you can find some videos.
Sounds like cheap plugs/wires, or egr.
