Old 09-20-2019, 12:09 AM   #11 (permalink)
Originally Posted by Adrien View Post
I'm surprised that you say the stock probe is enough, as they can only read between lambda 0.90 to 1.10 (13 to 16 AFR) , however if the injectors don't flow enough, the ethanol mixture could be leaner than this, over lambda 1.40, which is beyond what a narrowband probe can interpret, am I right ?
IIRC the same probe was retained in the flexfuel versions of those engines.
Old 09-29-2019, 06:29 AM   #12 (permalink)
Corolla E12 - '03 Toyota Corolla E12
You are in Brazil aren't you ? Do you have any info on running on Ethanol vs gasoline on Vvti engines ?
More specifically, does the engine seems less powerfull like it did when I tried Ethanol?
Old 10-05-2019, 01:13 AM   #13 (permalink)
Yes.
IIRC all the flexfuels I drove on ethanol weren't fitted with VVT.
Usually the engine gets more powerful running on ethanol. It's a matter of tuning for you to get it running as it's supposed to do.
