Old 09-11-2010, 08:07 PM   #1 (permalink)
Versa - '12 Nissan Versa Hatchback S
90 day: 39.65 mpg (US)
New Guy with long commute
Hello everyone. I stumbled onto this site while researching an idea I have for modifying a power steering pump with an electric clutch commonly found on ac compressors. I want to do this with control circuitry to control when the clutch is engaged and when it is off for optimal savings. I will also be doing a mod to control when the field wire for the alternator is energized.
I drive a 2001 Pontiac Grand Prix with the 3.8L non supercharged engine. I have a 45 mile commute to and from work, so I am seriously interested in saving fuel. Unfortunetley I cannot afford to get rid of this vehicle right now, so I am looking to scrape together the parts I need to get things done.
Anyway, I look forward to learning as much as I can from everyone here.
Old 09-12-2010, 12:13 AM   #2 (permalink)
Just pull the belt off altogether if you can and be done with it. Power steering is quite manageable w/o power.
Old 09-12-2010, 08:24 AM   #3 (permalink)
I would except it is a serpentine system, and the car weighs almost 3500 lbs with most of the weight on the front wheels. I have tried turning it without power steering and it is very hard to move. Especially at low speeds.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
How long should a driving loop be for A-B-A testing? Zyzzyx General Efficiency Discussion 3 06-09-2010 03:24 PM
I took out a guy on a bicycle with my truck.. Chris D. The Lounge 16 11-01-2008 10:00 PM
Morning Commute Observation Doofus McFancypants EcoModding Central 10 10-21-2008 10:46 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 04:11 PM
