Old 06-25-2010, 07:56 AM   #21 (permalink)
Send a message via MSN to markweatherill
I had this idea once of getting some energy out of the engine coolant's 'waste' heat by running the coolant into an additional cylinder, letting it expand as steam, condensing it after.
Or running a steam turbine off it to drive the alternator.
Old 06-27-2010, 01:00 AM   #22 (permalink)
A simpler system could use a conventional turbo to generate power instead of presurizing the intake.
The conceptially simplest would be to have it run a generater and if you want to tap waste heat along with exhaust pressure add a recirculating water injection system right ahead of the turbo. This would use the waste heat to create more " turbo boost " making more power, but would also require a condensor to reclaim this water, making the system larger and more complicated.
A generator system of this type could likely handle all the cars electrical needs, and might even be able to handle electric driven a/c, at least at steady hwy speeds.
Mimicking Gen3 Prius Exhaust Heat Recovery Daox EcoModding Central 77 08-01-2018 04:16 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Replacement Exhaust/muffler 97 Metro RedRocket321 EcoModding Central 28 07-06-2008 02:58 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
Automotive X Prize - would a modded Civic VX make it? Krieg EcoModding Central 31 01-02-2008 07:06 AM
