Old 08-24-2019, 09:11 PM   #1 (permalink)
The black one - '99 Chevy Metro Base
90 day: 40.55 mpg (US)
EOC and Ultragauge
Are any of you doing engine off coasting and using a scan gauge or Ultragauge?
With the engine off, that would shut off the Ultragauge also and make the results incorrect.
Has anyone altered the wiring system to eliminate that?
Old 08-26-2019, 11:42 AM   #2 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Wrong area, but I think the SG has a hybrid setting that will keep it on for a minute or so to keep gathering data. My UG stays on whenever the ignition is on, so as long as you don't shut off the ignition to kill the engine you should be good to go.
Old 08-26-2019, 05:10 PM   #3 (permalink)
Thank you for the response. Sorry I didn't realize it was the wrong area, I'm new here and still trying to learn where everything is located.
I think I can shut the fuel injector off without turning the ignition off. Will have to check the factory service manual wiring diagram.
Old 08-27-2019, 12:50 PM   #4 (permalink)
One of the Moderators should be able to move it if needed.
I have an '05 Jeep Liberty and I wired the injectors through a continuous duty relay with a toggle switch to use as a kill switch. The only thing is that my Jeep is an automatic, so I only use it under deceleration to engine brake, mainly when towing. it works the same as Deceleration Fuel Cut Off (DFCO) but it gives me control of it. I wired the toggle switch to also illuminate a bright red LED on my dash above the steering wheel, so that I can clearly see when I have the injectors cut off.
The Following User Says Thank You to Joenavy85 For This Useful Post:
modified metro (08-27-2019)
Old 08-27-2019, 02:03 PM   #5 (permalink)
I drive a 99 Chevy metro, which has DFCO, but you have to have the trans in gear for it to work, which slows the car much quicker than coasting out of gear. It also has decel enleanment which does help, but while my car is moving the idle is at 1200 rpm or higher, which doesn't help.
The EPA mpg rating is 34 in town and I average 40 to 42 mpg in town, except during the winter months.
I'm have been reading as much as I can on the forum about pulse and glide and EOC. I have been trying out the pulse and glide around town. Going to take some practice to get the hang of it.
