Old 02-01-2013, 08:13 PM   #1 (permalink)
LeZX2's Avatar
The red one - '00 Ford Zx2
Team ZX2
90 day: 37.98 mpg (US)
Inducing dfco
Hey guys, my car (ford zx2) seems to have very specific parameters for dfco. It seems to only work when going from above 55mph and stops at 40mph and even if i keep the rpm above 2500 below 40mph it keeps the injectors on.
Is there any way to cheat these parameters or easily change them? Right now dfco seems pretty useless, as in my daily drive i can only dfco once
Any insight is appreciated, thanks in advance!
Old 02-01-2013, 09:13 PM   #2 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
coast
assuming standard transmission
(3 pedals)
just coast .
in neutral , clutch released .
coasting does not waste kinetic energy the way that DFCO does
FE will be improved over what DFCO would provide if DFCO were functioning as early systems were designed , which appears to be your goal ?
The Following User Says Thank You to mwebb For This Useful Post:
LeZX2 (02-01-2013)
Old 02-01-2013, 10:50 PM   #3 (permalink)
90 day: 51.82 mpg (US)
mwebb's right: most of the time, you're better off coasting.
For those rare times that DFCO is beneficial, you might want to check in on this thread to see what's brewing in terms of DIY DFCO:
http://ecomodder.com/forum/showthrea...ars-24773.html
Old 02-01-2013, 11:21 PM   #4 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
My wife's 08 Avenger has DFCO also, but with a 4 sp auto. DFCO only engages above 60 mph, and fuel cuts in @55mph. However, I can extend it lower if I pull the shifter down into 3rd before slowing down to 55. Then it will continue to about 43mph.
The Following 2 Users Say Thank You to ECONORAM For This Useful Post:
LeZX2 (02-01-2013), Thelismor (09-25-2013)
Old 02-01-2013, 11:43 PM   #5 (permalink)
LeZX2's Avatar
Team ZX2
Well i guess that coasting would be better, i was trying to get into the habit of keeping it in gear to reduce brake use more but now that i think about it i guess i should just lift off the throttle earlier and coast
Thanks for the input
Old 02-01-2013, 11:57 PM   #6 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Agreed with every1 when in a manual just coast engine off much more efficient, the only reason i use dfco is because of the auto tranny im not risking shutting off and the fact that in 4th gear of my auto tranny automatically switches into neutral while inducing dfco above 45mph
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 02-06-2013, 07:56 PM   #7 (permalink)
halos.com
UPdate. I was specifically watching the speedo after pulling the gear selector into 3rd while keeping the DFCO engaged...and it stayed until 35mph before fuel flow resumed.
