Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-02-2008, 12:36 AM   #1 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 133.3 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
Wind power testing idea
It was crazy windy this weekend, so the wife and I decided to make the best of it and go fly a kite. Yay! We went out the lake near our house, because we knew of several large open areas that should suffice. Once we get there she picks out this nice area near the water and SURROUNDED BY TREES! I humor her and the kite actually made it up in the air! Then I started noticing that when the gusts would die down, it would fall just a couple feet and then it would be below the tree line. It would just flutter eratically, then once it was completely behind the tree, just fall. That got me thinking. If you're considering a new wind generator install and are unsure of the effect of nearby obsticles, go try to fly a kite there. If there's not enough wind to keep a kite up almost any time, it probably won't generate very much electricity too. I was also thinking some sort of scale could be attached to tell how hard it was pulling. That would give a quanitative value that could be compared to existing installations instead of just a qualitative feeling. What do you think? Does it have any merit, or does this idea not hold any air?
Old 07-09-2008, 04:11 PM   #2 (permalink)
Yes, this is sometimes used in wind site assessment to see actual turbulence or loss of wind due to obstacles. Sometimes streamers are attachted to the kite string at intervals to see what is happening at different levels.
Old 07-09-2008, 06:42 PM   #3 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Good thinking!
Flying a slow model plane could help as well.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 08-20-2008, 04:44 PM   #4 (permalink)
That's about as elegant as engineering can get!
Old 08-21-2008, 09:56 AM   #5 (permalink)
EcoModding Newbie
Parachute - '03 Chevrolet Tracker LX
90 day: 28.55 mpg (US)
Peon - '95 Plymouth Neon Highline baby!
90 day: 31.39 mpg (US)
Slocus Wagon - '06 Ford Focus SE
People do put up anemeters with a data logger before they plunk down 20k for windmill. The kite idea is good too though Usually the solution is go 30' above the trees with the tower.
You can also look for windswept hardwood trees as an indicator of wind speeds too.
Old 08-21-2008, 12:09 PM   #6 (permalink)
There are some really good maps of wind energy potential available, but it still takes some knowledge and on-site study to determine how tall the tower must be (usually at least 80 feet, often 100 to 120 feet or even taller). Often the cost of an anemometer isn't justified on anything less than a wind farm sized machine, as an anemometer and the tower needed to get it up 90 or more feet is a sizable percentage of what a potential wind generator and tower will cost. In my opinion, you aren't going to get much of a wind machine for less than $20k installed with tower, and one capable of powering a house may be $50k to $80k or more. Conservation methods in the home have a great payback if you are planning to use wind or solar to generate electricity.
As IndyIan mentioned, a rule of thumb is to be at least 30 feet above anything within 500 feet of the tower.
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
tuft testing, vortex generators, and God's own wind tunnel jim-frank Aerodynamics 10 06-27-2009 02:48 PM
Wind Power trikkonceptz Fossil Fuel Free 13 10-09-2008 01:32 AM
Bullfrog Power wind farm owner dumps his Insight for a Prius MetroMPG General Efficiency Discussion 0 12-16-2007 11:50 PM
