Old 06-05-2009, 05:01 PM   #1 (permalink)
Honda/Acura Gear ratio
There is alot of information about gear ratios for hondas and geos on the web but my wife refuses to drive a manual. We have 1995 integra. Does anyone know the gear ratio for honda automatics? Can I change to a different Trans with a taller final drive (differential) for better fuel ecconomy?
Old 06-05-2009, 07:27 PM   #2 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
Your easiest option is bigger tires, this will effectively raise your ratios. If you insist on a transmission mod look into Honda CRV FWD parts. I looked for a few minutes but did not see trustworthy ratio data on automatics but I know the CRVs transmission is the same design and will fit. I don't know if it has different ratios. There might be a way to mod your auto to shift manually.
Good luck
Old 06-08-2009, 07:06 PM   #3 (permalink)
Are there other related items that I should be looking at? like lock up torque converters? and stall speed?
Story of a custom 5th gear for a '98 Ford Escort ZX2: +6% MPG MetroMPG EcoModding Central 14 03-05-2020 07:20 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-09-2014 12:22 AM
Suzuki Burgman modification (aerodynamics + gearing mods) janvos39 Motorcycles / Scooters 165 10-27-2014 06:20 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 10:31 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 08:03 AM
