Old 02-24-2008, 11:20 AM   #1 (permalink)
direct cylinder injection
It was brought to my attention once more as it was thru popular mechanics in the 70's, that Texaco developed a direct cylinder injection system almost 50 yrs ago(TCCS) Texaco controled combustion system. There have been different variations worked with by different manufacturers over the yrs, and while there are some small pollution issues, the advantages far outweigh the problems.The texaco system was used on UPS trucks in the 70's.
The system allows for up to a 12:1 compression ratio to be used and an air fuel ratio of up to 40:1 . It also allows for the use of broad cut fuel or multiple fuel use.
www.egr.msu.edu/erl/ME444/lectures/1115.ppt or
http://216.109.125.130/search/cache?...icp=1&.intl=us
Old 02-24-2008, 01:22 PM   #2 (permalink)
H4MM3R's Avatar
Here is some more info. It show gains of 15% in FE using direct injection
http://rb-k.bosch.de/en/powerconsump...ion/index.html
Old 02-24-2008, 02:38 PM   #3 (permalink)
GDI is pretty common today.
Old 02-24-2008, 03:04 PM   #4 (permalink)
H4MM3R's Avatar
I know at GM they have the Pontiac Solstice GXP that is GDI and the Cadillac CTS has that as an option.
Cylinder deactivation discussion diesel_john EcoModding Central 87 03-10-2014 06:42 PM
DIY - Water Injection Stormin' Norman DIY / How-to 46 12-28-2012 12:48 PM
Direct Injection Ethanol Boosting + Turbocharging Lazarus The Lounge 7 01-24-2009 04:27 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
