Old 03-21-2013, 12:36 AM   #1 (permalink)
betasniper's Avatar
Red - '01 Honda Insight CVT
Gen-1 Insights
House of Tudor
90 day: 59.17 mpg (US)
Civic Hybrid - '12 Honda Civic Hybrid
Bahamut - '18 Chevrolet Volt LT
Team Volt
Plug-in Hybrids
Saturn SW2 Gauge Pod
I wanted a gauge pod that didn't "obstruct" my view so I decided to make my own out of scrap material I had around.
This Is how I made my gauge pod for my Saturn SW2 A pillar:
Turning scrap ABS tube on lathe to outside diameter of the gauge:
Drilled Holes for roughing outline of pillar
Dremel to fit:
Aline gap between gauges protrusions with hole: (this was finished)
Constantly checking fit on Pillar
Repeat Dremeling to fit again if needed.
Front of gauge:
(square thing is camera reflection)
What should have happened next:
Cut hole for passing vacuum line and light wires in A pillar
Glue pod to pillar with amazing goop marine/rv/automotive/plumber/any really. (needs to be a glue that is flexible enough to fix plastics)
Attach wires to dimmer circuit so they could be removed somewhat easily
attach vacuum line to manifold (somewhere close to the intake runners is preferable)
Reinstall trim in car
Enjoy!
Tip for using dremel: When changing bits, loosen threaded collar then push bit further into the tool then pull it out. Made my tool change time go from about 15s to about 3s.
And other gauge pods I made turned:
: Brothers
: Dad's
The Following 3 Users Say Thank You to betasniper For This Useful Post:
cfg83 (03-21-2013), Piwoslaw (03-21-2013), War_Wagon (03-21-2013)
Old 12-15-2013, 05:26 PM   #2 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
Finally Finished (only took 9 months)
I turned on the lathe a Tee fitting with 2 barbs and an 1/8 NPT hole from a rectangular piece of scrap aluminum using a 4 jaw chuck. Took about 2 hours (most the time I was looking for the tools) to complete. Next Day I installed it within 30 minutes. I haven't Driven since I turned the Tee fitting, but there isn't any vacuum leaks from just starting the car for a minute and the gauge responds very quickly.
Pics under Hood:
Used 8.9mm fuel line to connect Tee to Manifold. The original connection was a hard plastic tube in a foam sleeve.
Name:	Tee Fitting.jpg
ID:	14251   Click image for larger version
Name:	Tee Vacuum Line.jpg
: Brothers
: Dad's
Old 12-16-2013, 08:36 AM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Great work- and the found materials make it even better!
Transmission type Efficiency
Old 12-16-2013, 12:05 PM   #4 (permalink)
...beats walking...
The QUESTION-of-the-DAY, however, is *how* are you attaching those gauge pods to the A-pillar moulding? Glue, screws, velcro, bubblegum, or what?
Old 12-17-2013, 12:48 AM   #5 (permalink)
betasniper's Avatar
Gen-1 Insights
House of Tudor
Team Volt
Plug-in Hybrids
I used Wood glue, but I suggest a glue meant for plastics as wood glue doesn't hold as well as I thought it would. I mentioned appropriate glues but didn't use one.
Here It is holding itself up while I'm sitting at a Red Light:
Car is warm. (Still haven't done the other three yet.)
Name:	Warm Idle Vacuum.jpg
: Brothers
: Dad's
Old 12-19-2013, 07:35 AM   #6 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Cool, I use an Ultragauge.
- Tony
