Old 06-28-2020, 04:39 PM   #21 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Check out Julians videos.
Calibrate your suspension travel with weights. Put X amount, and it compresses Y mm (or thou).
Then measure at desired speed.
You need means to measure distance to ground via an electronic sensor either by chassis to ground (linear) or suspension component (angle).
The Following User Says Thank You to teoman For This Useful Post:
aerohead (10-09-2020)
