Old 07-29-2019, 04:00 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
How to calculate pounds of force on decklid spoiler
For my flat decklid spoiler build I want to use countersunk neodymium magnets as the attachment mechanism. Flat fiberglass spoiler screwed into the magnets and magnetically attached to the decklid. How do I calculate the amount of aerodynmaic force I might encounter so I can acquire magnets with enough strength to hold, even at 70 mph in a windstorm?
Old 07-29-2019, 07:09 PM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I'm not sure you'll be able to calculate that to any degree of certainty without some data. Do you have a Magnahelic or any other type of pressure gauge?
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
California98Civic (07-29-2019)
Old 07-29-2019, 10:33 PM   #3 (permalink)
I was going to post in the other thread but you started this one five minutes later.
If you like (itchy, sticky) fiberglass then 0kay, but personally I'd go with Polymetal [or equivalent] or 1/8" sheet ABS. Polymetal is stiffer, but ABS can be heat-formed and cemented.
A Bonneville spoiler is subjected to low pressure on the bottom, just as a diverter is subjected to high pressure on the top. Use turnbuckles with magnets on the end.
"The Flat Earth Society has members all around the globe" -- The Flat Earth Society
Old 07-29-2019, 11:22 PM   #4 (permalink)
Cyborg ECU
... personally I'd go with Polymetal [or equivalent] or 1/8" sheet ABS. Polymetal is stiffer, but ABS can be heat-formed and cemented.
Polymetal! Of course. I had forgotten. I am going to start with just the spoiler, which has just one very mild curvature. Not making the side plate yet, probably, and its the part needing more bending. The rigidity of polymetal will be perfect.
Bonneville spoiler is subjected to low pressure on the bottom, just as a diverter is subjected to high pressure on the top. Use turnbuckles with magnets on the end. ...
Turnbuckles are perfect.
No gauges. There is no formula for an reasonable estimate? This aint a race car... seems like an estimate should be good enough if I build something twice as strong as estimated need and be fine, no?
Old 07-29-2019, 11:40 PM   #5 (permalink)
When you get the steady-state forces all figured out a gust or a semi will come along and give it a good blast.
The Following 2 Users Say Thank You to Frank Lee For This Useful Post:
aerohead (08-21-2019), freebeard (07-29-2019)
Old 07-29-2019, 11:57 PM   #6 (permalink)
The Arfon brothers bent the metal for their land speed record car around a tree trunk.
Consider a full size top piece with a underhung strip riveted to the back edge. Turn a flat plate into an airfoil, plus the mechanical advantage of the fasteners not being in a straight line.
A Magnahelic gauge can be simulated by two pieces of surgical tubing, a double-stoppered flask and a webcam. Technically, a downward-pointed U-bend in a single tube marked off in inches.
California98Civic (07-30-2019)
Old 07-30-2019, 07:34 AM   #7 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I will chime in with some mildly annoying clarification. Magnehelic is a model/brand of gauge which usually measures inches of water column. A more generic name would simply be inches gauge, low pressure gauge, or monometer.
To the OP, I would not attempt with magnets. I assume the idea is to not damage the vehicle but I would wager that neodymium magnets strong enough to do what you're asking may also lead to scratches in the paint.
Mounting it to somewhat disposable features like a tail lamp housing might be an option.
The Following 3 Users Say Thank You to ksa8907 For This Useful Post:
California98Civic (07-30-2019), Fat Charlie (05-15-2020), Frank Lee (07-30-2019)
Old 07-30-2019, 10:22 AM   #8 (permalink)
Good point. Perhaps for testing where changes are likely- or simply if you're uncertain about the permanency of it- a cheap scrapyard lid could be procured? Or take the nice lid off completely and fab a lid with integral spoiler.
Re: magnets: If you put tape down first to protect the paint from scratches I doubt the holding power would be seriously affected.
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
aerohead (08-21-2019), California98Civic (07-30-2019), Fat Charlie (05-15-2020)
Old 07-30-2019, 10:38 AM   #9 (permalink)
Moderator
Vman455's Avatar
I don't know how one would be able to come up with a formula for estimation since this will vary on every car due to shape and lift coefficient, and won't be constant on the car anyway (there might be different pressure at the outside edges of the trunk lid than the middle, for instance).
As freebeard said, you can make a cheap pressure gauge like we used to use at one of the organ building shops I worked in (but only one--the others, we used Magnahelics which are much easier to get an accurate reading from). Take a length of clear vinyl tubing, bend it into a U, zip tie it to a ruler, fill the U with some water. Keep one end in the cabin for atmospheric pressure, put the other end at a right angle to the flow in the area of interest. The difference between the height of the water in each arm of the U is your pressure differential.
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
Old 07-30-2019, 06:33 PM   #10 (permalink)
Cyborg ECU
All great points about the gauges and measuring/calculating pressure. Thanks. Re: magnets on the body paint surface... I was imagining an insulator of some sort, probably thin rubber or soft plastic, which would make removal of the magnet easier without scratching. Now, realize that my paint is, well, "mature" and not "show room" spec... I just don't try to deliberately scratch it up.
