Old 04-12-2012, 07:31 AM   #21 (permalink)
xAviar - '06 Scion xA
Dr. Grey - '02 Ford F-150 Supercrew
[QUOTE=Fosters80;299680]Its been a while since I had one of these, and I'm not able to get at my resources at the moment, but I seem to remember the 93 DX being prone to ECU failure. Try removing it and taking the cover off the ECU, there was a spot on the board that would be noticeably burnt. [QUOTE]
Not to toot my own horn , but "beep beep"
The Following User Says Thank You to Fosters80 For This Useful Post:
Cd (04-12-2012)
Old 04-12-2012, 08:20 PM   #22 (permalink)
Originally Posted by Cd View Post
OK - You have my attention . That sounds like something I should try for sure . How do I go about doing this ?
BTW , I love your project car. You do amazing work. Really looking forward to seeing that car on the road.
relays need 4 terminals.
fused power from the battery or a constant source.
ground.
trigger wire - comes on when ignition is on. Yellow and black pretty much all over the engine compartment.
load (to the fuel pump).
Old 04-12-2012, 09:26 PM   #23 (permalink)
Cd
Ultimate Fail
Cd's Avatar
ground.
Sounds simple enough. I"m sure i'd manage to screw something to hell though.
If the replacement ECU doesn't fix things, I'll give this a shot.
Old 04-14-2012, 08:36 PM   #24 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I don't want to call it fixed just yet, but the replacement ECU plugged in and the car fired right up.
- in misty weather at that ( the main symptom before was that the car would not start when it was humid. )
Thanks everyone !
'93, 1993, ecu, honda civic
